I mostly think that importing passwords from a legacy forum is a Bad Idea. There are almost certainly a bunch of horrible passwords and it seems like making people change their password when they get a shiny new forum is a fine idea, but it seems that people want to do that anyway.
There’s a plugin that offers Migrated password hashes support. I just put that code into the vbulletin importer for some folks. Should I leave it in or take it out before I submit the PR with other useful stuff in it?
Since the passwords are completely ignored unless the plugin is installed, it doesn’t hurt much to just include the passwords, but I’d probably add a switch so that they’d not be included by default.
I think it’s fine to always import previous password hashes & salts. It’s just text, so that won’t take too much space. That way, people who want to allow their users to use their previous password can just add the linked plugin and be done.
Hi all. I am trying to migrate a forum from discuz x to discourse (v2.0.0.beta4), but running the corresponding import script results
creating users
1 / 242 ( 0.4%) /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activemodel-5.1.4/lib/active_model/attribute_assignment.rb:48:in _assign_attribute': unknown attribute 'import_pass' for User. (ActiveModel::UnknownAttributeError) from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activemodel-5.1.4/lib/active_model/attribute_assignment.rb:40:inblock in _assign_attributes’
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activemodel-5.1.4/lib/active_model/attribute_assignment.rb:39:in each' from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activemodel-5.1.4/lib/active_model/attribute_assignment.rb:39:in_assign_attributes’
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activerecord-5.1.4/lib/active_record/attribute_assignment.rb:26:in _assign_attributes' from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activemodel-5.1.4/lib/active_model/attribute_assignment.rb:33:inassign_attributes’
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activerecord-5.1.4/lib/active_record/core.rb:337:in initialize' from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activerecord-5.1.4/lib/active_record/inheritance.rb:66:innew’
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activerecord-5.1.4/lib/active_record/inheritance.rb:66:in new' from /home/localadmin/git/discourse/script/import_scripts/base.rb:313:increate_user’
from /home/localadmin/git/discourse/script/import_scripts/base.rb:242:in block in create_users' from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rack-mini-profiler-0.10.7/lib/patches/db/mysql2.rb:6:ineach’
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rack-mini-profiler-0.10.7/lib/patches/db/mysql2.rb:6:in each' from /home/localadmin/git/discourse/script/import_scripts/base.rb:230:increate_users’
from script/import_scripts/discuz_x.rb:163:in block in import_users' from /home/localadmin/git/discourse/script/import_scripts/base.rb:824:inblock in batches’
from /home/localadmin/git/discourse/script/import_scripts/base.rb:823:in loop' from /home/localadmin/git/discourse/script/import_scripts/base.rb:823:inbatches’
from script/import_scripts/discuz_x.rb:137:in import_users' from script/import_scripts/discuz_x.rb:56:inexecute’
from /home/localadmin/git/discourse/script/import_scripts/base.rb:46:in perform' from script/import_scripts/discuz_x.rb:1064:in’
It seems that the custom field “import_pass” are failed to handle somewhere.
Does this happen because some plugins are absent with my environment?
Thanks. Now the import_users passed, but now it failed on import_categories when executing
raw = process_discuzx_post(row['rules'], nil)
if @bbcode_to_md
raw = raw.bbcode_to_md(false) rescue raw
category.topic.posts.first.update_attribute(:raw, raw)
with error
creating categories
14 / 52 ( 26.9%) script/import_scripts/discuz_x.rb:288:in `block (2 levels) in import_categories': undefined method `update_attribute' for nil:NilClass (NoMethodError)
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activesupport-5.1.4/lib/active_support/core_ext/object/try.rb:17:in `public_send'
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activesupport-5.1.4/lib/active_support/core_ext/object/try.rb:17:in `try!'
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/activesupport-5.1.4/lib/active_support/core_ext/object/try.rb:6:in `try'
from /home/localadmin/git/discourse/script/import_scripts/base.rb:451:in `create_category'
from /home/localadmin/git/discourse/script/import_scripts/base.rb:417:in `block in create_categories'
from /home/localadmin/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rack-mini-profiler-0.10.7/lib/patches/db/mysql2.rb:6:in `each'
from /home/localadmin/git/discourse/script/import_scripts/base.rb:398:in `create_categories'
from script/import_scripts/discuz_x.rb:263:in `import_categories'
from script/import_scripts/discuz_x.rb:57:in `execute'
from /home/localadmin/git/discourse/script/import_scripts/base.rb:46:in `perform'
from script/import_scripts/discuz_x.rb:1065:in `<main>'
