Importar una copia de seguridad de Discourse en una base de datos PostGreSQL
Dear Discourse team,
Please could you advise me how can I import a backup into PostGreSQL DB.
I am using
psql  --username=xx--password=xx  mydb < C:\...\backup.tar
but I get a weird message:
orden \Y¾³s'ìfu7}Ø$M²ÏñT?ýï>/ no válida
ERROR:  secuencia de bytes no válida para codificación «UTF8»: 0x8b
Thanks so much for your help!
Best regards,
Alexandra.
First extract the tar file
tar xf backup.tar
Then
zcat dump.sql.gz | psql -u username mydb
On Windows, you might have to use a tool like Winrar multiple times to go from backup.tar.gz to backup.tar to dump.sql.gz to dump.sql and then
psql -u username mydb < dump.sql
Thanks so much Richard!
