GitHub에서 가져온 가져오기 스크립트로 Xenforo를 가져오면 오류가 대량으로 발생합니다
오류:
:/var/www/discourse# bundle exec ruby script/import_scripts/xenforo.rb
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/mini_profiler/profiling_methods.rb:87:in `alias_method': undefined method `call' for class `Redis::Client' (NameError)
        klass.send :alias_method, without_profiling, method
Did you mean?  caller
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/mini_profiler/profiling_methods.rb:87:in `profile_method'        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/mini_profiler/profiling_methods.rb:69:in `counter_method'        from /var/www/discourse/config/initializers/006-mini_profiler.rb:91:in `<main>'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/engine.rb:667:in `load'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/engine.rb:667:in `block in load_config_initializer'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activesupport-7.0.8/lib/active_support/notifications.rb:208:in `instrument'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/engine.rb:666:in `load_config_initializer'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/engine.rb:620:in `block (2 levels) in <class:Engine>'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/engine.rb:619:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/engine.rb:619:in `block in <class:Engine>'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/initializable.rb:32:in `instance_exec'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/initializable.rb:32:in `run'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/initializable.rb:61:in `block in run_initializers'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:228:in `block in tsort_each'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:350:in `block (2 levels) in each_strongly_connected_component'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:422:in `block (2 levels) in each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:431:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:421:in `block in each_strongly_connected_component_from'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/initializable.rb:50:in `each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/initializable.rb:50:in `tsort_each_child'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:415:in `call'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:415:in `each_strongly_connected_component_from'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:349:in `block in each_strongly_connected_component'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in `each'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in `call'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in `each_strongly_connected_component'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:226:in `tsort_each'
        from /usr/local/lib/ruby/3.2.0/tsort.rb:205:in `tsort_each'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/initializable.rb:60:in `run_initializers'
        from /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8/lib/rails/application.rb:372:in `initialize!'
        from /var/www/discourse/config/environment.rb:7:in `<top (required)>'
        from /var/www/discourse/script/import_scripts/base.rb:16:in `require_relative'
        from /var/www/discourse/script/import_scripts/base.rb:16:in `<top (required)>'
        from <internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
        from script/import_scripts/xenforo.rb:17:in `<main>'
