Accesso a Instagram? Possibile/Già fatto?
I’ve browsed a couple of topics regarding this.
This topic was solved that it doesn’t return e-mail which doesn’t really help:
https://meta.discourse.org/t/configuring-instagram-login-for-discourse/51642
Has anyone configured Instagram login for their forum? Is this possible? Is there a guide?
A massive part of my target audience is primarily on Instagram, so this would be considered essential for my forum. Thank you.
It’s just OAuth2.0, for which a plugin exists. You should start by reading their documentation:
https://www.instagram.com/developer/authentication/
2 Mi Piace
I don’t think a plugin is necessary, is it? Do I have to do this using Custom OAuth2?
If so, perhaps there should be a change on the existing result for Instagram logins in Admin settings, if the DD has changed.
A step-by-step guide would be helpful as this differs from other auths, as the topic in OP clearly states.
chrome_2019-03-09_16-21-34
It is and yes. Instagram doesn’t send back an email address via the API so Discourse has nothing to key on. You’re starting from scratch here, I’m afraid.
1 Mi Piace
Thank you for the response.
Perhaps deprecate the Instagram section in Admin settings for logins to prevent users from being confused, then?
Yeah, that probably makes sense @codinghorror
I don’t know, maybe, I’m unsure why we ever added this if it never worked properly. What do you think @sam?
Wait, it should work fine without email, you still get to forget 1 password, which is awesome.
We would ask you for your email on first signup and then confirm it.
Also associate account should work.
Agree we should have some sort of official howto here like the other providers have.
3 Mi Piace
@hawk maybe community team can take this as a writing-a-howto test, if we don’t like it after testing it in the process of writing the howto, we can pull it.
2 Mi Piace
In regards to this, I’ve fiddled around with it a bit and it seems to work fine, at least in Sandbox Mode, contrary to what I’ve been told before, and contrary to what I was told in this thread. It did take a long time going across websites to find some help with the docs, as I’m not as tech-savvy as some.
The only difference I’ve come across compared to other authentications, is the same which is stated here:
https://meta.discourse.org/t/configuring-instagram-login-for-discourse/51642/15?u=hanzo1
When he says “convince” he means a Screencast, showing the ins-and-outs of what you intend to do. I sent in a 3 minute screencast showing the admin panel’s Instagram feature, the logging in, logging out, and the keys I generated in the Developer API for Instagram.
I have confirmed that although OAuth2 is the recognized standard, it is not required for this to work. I have an account, working, that has signed up, and logged in, with Instagram’s authentication as-is on Discourse, no OAuth2 or Plugin necessary.
That being said, no more than ten individuals can sign up, before Sandbox Mode locks itself. Once it is approved, it will leave Sandbox Mode, and go to “Live”.
Here is a pic of the page, showing status, on Instagram:
Why it is so difficult, I have no idea; as the OP’s thread states, it should be in line with FB’s, given FB owns IG, but I guess not. Screencast is required.
3 Mi Piace
Thanks to @jennlevbird we now have a howto
https://meta.discourse.org/t/configuring-instagram-login-to-use-with-discourse/111410
We tested the process and confirm it is working.
8 Mi Piace
Hi Sam, thanks so much for this update I appreciate your support. This is great.
1 Mi Piace
This topic was automatically closed after 5 days. New replies are no longer allowed.
L’accesso con Instagram è stato sostituito dall’accesso con Facebook.
5 Mi Piace
È ancora solo una raccomandazione o hanno effettivamente disabilitato l’API? Se è completamente disabilitata, dovremmo rimuovere la funzionalità dal core di Discourse.
Modifica: @Canapin è un passo avanti
3 Mi Piace
Immagino si tratti di una “rimozione soft”, come piace usare alle aziende tecnologiche: chiunque lo stia ancora usando potrà rimanere per qualche anno, ma senza nuove registrazioni. (Non l’ho effettivamente verificato.)
@edbobkov, nel topic eliminato, ha scritto:
Nota che Basic Display non è uno strumento di autenticazione. I dati restituiti dall’API non possono essere utilizzati per autenticare gli utenti della tua app o per effettuare il loro accesso. Se la tua app utilizza i dati dell’API per autenticare gli utenti, verrà respinta durante la revisione dell’app. Se hai bisogno di una soluzione di autenticazione, utilizza invece Facebook Login.
Quindi è disponibile solo per i proprietari di account business.
“Respingimento durante la revisione dell’app” mi fa pensare a “le configurazioni esistenti continuano a funzionare”.
Inoltre, scommetto che aspetteranno che la pandemia sia praticamente conclusa prima di iniziare a fare pressione sulle persone per smettere.
3 Mi Piace
