Integrating Discourse, Caddy, and WordPress with Docker Ports for Reverse Proxy
This is my first post and wanted to provide a guide I made with our friend ChatGPT after struggling for days to figure out how to get Caddy working for reverse proxy for Discourse installed with the office instructions. I used info I found on Caddy’s forum here. Caddy Discourse Setup . This may be straight forward but for those of us just getting started with Discourse a bit of a lift to get it going.
Thanks for an obviously great community.
Overview
This guide provides a step-by-step process to set up Discourse with Caddy as a reverse proxy, alongside a WordPress installation, using Docker Compose. These instructions are designed for a typical Ubuntu 22 LTS server and demonstrate how to integrate multiple services while ensuring a clean and reproducible setup.
Prerequisites
Ensure the following prerequisites are met before proceeding:
  1. Docker and Docker Compose:
bash
Copy code
apt update && apt install docker docker-compose -y
  1. Discourse Installed:
  1. Domain Names:
  • A primary domain for WordPress (e.g., website.com).
  • A subdomain for Discourse (e.g., forum.website.com).
Step 1: Configuring docker-compose.yml
The docker-compose.yml file defines services for Caddy (reverse proxy), WordPress, and MySQL.
File Location
Save the file as /etc/docker-services/docker-compose.yml.
Configuration
yaml
Copy code
version: '3.8'
services:
  caddy:
    image: caddy:latest
    container_name: caddy
    restart: always
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - ./Caddyfile:/etc/caddy/Caddyfile
      - caddy_data:/data
      - caddy_config:/config
    networks:
      - caddy_net
  wordpress:
    image: wordpress:latest
    container_name: wordpress
    restart: unless-stopped
    environment:
      WORDPRESS_DB_HOST: db
      WORDPRESS_DB_USER: example_user
      WORDPRESS_DB_PASSWORD: example_password
      WORDPRESS_DB_NAME: example_db
    volumes:
      - ./wordpress:/var/www/html
    networks:
      - caddy_net
  db:
    image: mysql:5.7
    container_name: wordpress_db
    environment:
      MYSQL_ROOT_PASSWORD: example_password
      MYSQL_DATABASE: example_db
      MYSQL_USER: example_user
      MYSQL_PASSWORD: example_password
    volumes:
      - db_data:/var/lib/mysql
    networks:
      - caddy_net
volumes:
  caddy_data:
  caddy_config:
  db_data:
networks:
  caddy_net:
    external: true
Step 2: Setting Up the Caddy Reverse Proxy
Caddy proxies requests to both Discourse and WordPress and manages HTTPS certificates.
File Location
Save the configuration as /etc/docker-services/Caddyfile.
Configuration
caddyfile
Copy code
website.com {
    reverse_proxy wordpress:80
forum.website.com {
    reverse_proxy app:80
This configuration ensures:
  • Requests to website.com are proxied to the WordPress container.
  • Requests to forum.website.com are proxied to the Discourse container.
Step 3: Configuring Discourse
Update app.yml to integrate Discourse with Caddy and the Docker network.
File Location
Located in /var/discourse/containers/app.yml.
Configuration Changes
  1. Expose Non-Standard HTTP Ports:
yaml
Copy code
expose:
  - "8880:80"   # http
  1. Remove SSL Templates:
yaml
Copy code
# - "templates/web.ssl.template.yml"
# - "templates/web.letsencrypt.ssl.template.yml"
  1. Set Docker Network:
yaml
Copy code
docker_args:
  - '--network caddy_net'
networks:
  caddy_net:
    external: true
  1. Rebuild Discourse: Apply the changes by rebuilding the Discourse container:
bash
Copy code
cd /var/discourse
./launcher rebuild app
Step 4: Deploy the Services
Start the Docker services for Caddy and WordPress:
  1. Navigate to the Docker Compose directory:
bash
Copy code
cd /etc/docker-services
  1. Launch the containers:
bash
Copy code
docker compose up -d
Step 5: Testing and Verification
  1. Verify Running Containers:
bash
Copy code
docker ps
  1. Access WordPress: Navigate to:
arduino
Copy code
https://website.com
  1. Access Discourse: Navigate to:
arduino
Copy code
https://forum.website.com
  1. Check Logs:
  • Caddy:
bash
Copy code
docker logs caddy
  • Discourse:
bash
Copy code
tail -f /var/discourse/shared/standalone/log/rails/production.log
Troubleshooting
  1. Discourse Not Responding:
  • Ensure Discourse is bound to port 8880.
  • Verify the container is connected to caddy_net:
bash
Copy code
docker network inspect caddy_net
  1. Caddy SSL Errors:
  • Check Caddy’s certificate logs in /data.
  1. Rebuild Issues:
  • Ensure the caddy_net network is active when rebuilding Discourse:
bash
Copy code
docker network ls
Conclusion
This guide demonstrates how to integrate Discourse, Caddy, and WordPress using Docker Compose and a reverse proxy configuration. By following these steps, you can achieve a modular and secure setup for your own website infrastructure.
You used an Arduino for this?
