Invalid Access when attempting to delete the About This Category topics
The discussion revolves around an “Invalid Access” error when attempting to delete the “About This Category” topic using the Discourse API. nottrobin encountered this issue while testing the API in a local development environment and suspected the “Can’t verify CSRF token authenticity” warning in the application logs.
However, nottrobin discovered that the issue is specific to the automatically created first topic in a category, which cannot be deleted. The user found that deleting other topics worked fine.
nottrobin was corroborated by Stephen, who explained that “About the Category” topics are special and are used for purposes such as the category description, which is why they cannot be deleted.
Testing discourse in local development, from GitHub - discourse/discourse: A platform for community discussion. Free, open, simple. · GitHub master with
./bin/docker/boot_dev --init
./bin/docker/rails s
I get an error when trying to delete a topic as per the API docs with:
$ curl -X DELETE "http://localhost:3000/t/12.json?api_key=xxxx&api_username=robin"
{"errors":["You are not permitted to view the requested resource."],"error_type":"invalid_access"}
In the application logs I see:
D, [2019-02-12T12:38:30.520131 #764] DEBUG -- : Delivering messages [] to client 11cd9108a3584397adf634286781846f for user 1
I, [2019-02-12T12:38:31.123471 #764]  INFO -- : Started DELETE "/t/12.json?api_key=[FILTERED]&api_username=robin" for 172.17.0.1 at 2019-02-12 12:38:31 +0000
I, [2019-02-12T12:38:31.182310 #764]  INFO -- : Processing by TopicsController#destroy as JSON
I, [2019-02-12T12:38:31.183726 #764]  INFO -- :   Parameters: {"api_key"=>"[FILTERED]", "api_username"=>"robin", "id"=>"12"}
W, [2019-02-12T12:38:31.185032 #764]  WARN -- : Can't verify CSRF token authenticity.
D, [2019-02-12T12:38:31.187818 #764] DEBUG -- :   ApiKey Load (0.9ms)  SELECT  "api_keys".* FROM "api_keys" WHERE "api_keys"."key" = 'f866509cc1675d306ea53f0038c189668d8b71c31b022be43807f2fc96b41c8d' ORDER BY "api_keys"."id" ASC LIMIT 1
D, [2019-02-12T12:38:31.190743 #764] DEBUG -- :   User Load (0.9ms)  SELECT  "users"."id", "users"."username", "users"."created_at", "users"."updated_at", "users"."name", "users"."seen_notification_id", "users"."last_posted_at", "users"."password_hash", "users"."salt", "users"."active", "users"."username_lower", "users"."last_seen_at", "users"."admin", "users"."last_emailed_at", "users"."trust_level", "users"."approved", "users"."approved_by_id", "users"."approved_at", "users"."previous_visit_at", "users"."suspended_at", "users"."suspended_till", "users"."date_of_birth", "users"."views", "users"."flag_level", "users"."ip_address", "users"."moderator", "users"."title", "users"."uploaded_avatar_id", "users"."locale", "users"."primary_group_id", "users"."registration_ip_address", "users"."staged", "users"."first_seen_at", "users"."silenced_till", "users"."manual_locked_trust_level" FROM "users" WHERE "users"."username_lower" = 'robin' LIMIT
1
D, [2019-02-12T12:38:31.194786 #764] DEBUG -- :   Topic Load (1.0ms)  SELECT  "topics"."id", "topics"."title", "topics"."last_posted_at", "topics"."created_at", "topics"."updated_at", "topics"."views", "topics"."posts_count", "topics"."user_id", "topics"."last_post_user_id", "topics"."reply_count", "topics"."featured_user1_id", "topics"."featured_user2_id", "topics"."featured_user3_id", "topics"."avg_time", "topics"."deleted_at", "topics"."highest_post_number", "topics"."image_url", "topics"."like_count", "topics"."incoming_link_count", "topics"."category_id", "topics"."visible", "topics"."moderator_posts_count", "topics"."closed", "topics"."archived", "topics"."bumped_at", "topics"."has_summary", "topics"."archetype", "topics"."featured_user4_id", "topics"."notify_moderators_count", "topics"."spam_count", "topics"."pinned_at", "topics"."score", "topics"."subtype", "topics"."slug", "topics"."deleted_by_id", "topics"."participant_count", "topics"."word_count", "topics"."excerpt", "topics"."pinned_globally", "topics"."pinned_until", "topics"."fancy_title", "topics"."highest_staff_post_number", "topics"."featured_link" FROM "topics" WHERE ("topics"."deleted_at" IS NULL) AND
"topics"."id" = 12 LIMIT 1
D, [2019-02-12T12:38:31.197756 #764] DEBUG -- :   Category Exists (0.7ms)  SELECT  1 AS one FROM "categories" WHERE "categories"."topic_id" = 12 LIMIT 1
I, [2019-02-12T12:38:31.199614 #764]  INFO -- : Completed 403 Forbidden in 15ms (Views: 0.1ms | ActiveRecord: 3.4ms)
I’m guessing “Can’t verify CSRF token authenticity” is the relevant bit here. But I don’t know how to obtain a CSRF token, and I assume it shouldn’t be needed anyway when authenticating with an API key, similar to other authenticated endpoints.
Is there any way around this?
I worked it out. It turns out that the automatically created first topic in the category, in this case “About the Docs category”, can’t be deleted for some reason.
I can delete all the others fine, which is all I need.
Correct, the about topics are special and are used for things such as the category description.
