Hello @team ,
I’ve stumble upon what we consider a small
bug regarding OAuth and the use of the Invite Only and Auth skip create confirm settings together.
Repro steps:
Invite only: enabled.Login required: enabled.Must approve users: enabled.Enable local loginsandEnable local logins via email: disabledAllow new registrations: enabled.- Configure
OAuth2 enabledand the rest of OAuth settings as appropriate (basically, to only allow authentication via OAuth). Auth skip create confirm: enabled
An admin generates an invitation, and the invited user access the invitation link. The sign-up pop-up appears (see below).
Expected behaviour
When Invite Only and Auth skip create confirm are both used, the sign-up pop-up form should not appear.
Disabling Invite Only (and keeping Auth skip create create confirm) make the pop up to disappear, as expected.
Cheers,
Ismael
