Invites assume user ID will be derived from email address
סיכום מבוסס בינה מלאכותית
The discussion revolves around the limitation of invite links assuming the user ID is derived from the email address. Jim_Coombes explains that in his Amateur Radio community, IDs are required to be call signs, but invite links do not allow him to specify the ID, causing issues for users with email addresses that do not match their call signs.
Codinghorror mentions that invitees can now specify their username when accepting the invite. However, Jim_Coombes wants to restrict this option and have the ability to specify the username himself.
Jim_Coombes has used the Customize feature to replace “username” with “callsign” in several places, which has helped reduce the issue.
The conversation also touches on the possibility of using CSV invite lists or Invite tokens to specify usernames. TechAPJ shares that CSV invite lists do not support this feature, but Invite tokens do, and provides a link to a relevant meta post: https://meta.discourse.org/t/generating-lots-of-invite-links/17563?u=techapj
In our Amateur Radio community, everyone has a licensed call sign. However while many may use that call sign as the first part before the @ symbol of their email address, there also many who have other email addresses. We require that IDs are call signs. So if I send and invite to someone who has their call sign in the first part of their email address - that works fine. But for those who do not - I am stuck. It appears that I cannot specify the ID that an invited person will have upon responding even though I know what it must be. If I am not missing something, this would be nice to have.
Jim
As of a few weeks ago, invitees can specify their username when accepting the invite – try it by sending an invite to one of your own email addresses.
3 לייקים
With some CSS trickery, you might even be able to change the username: field to be labeled callsign: instead :slight_smile:
לייק 1
That’s good but I really don’t want the person to have any option not to use their call sign which I will know from other databases and can specify. I will have a play with one of my other email addresses.
Jim
I have already used the Customize - Text Content substitution feature to replace “username” with “callsign” in as many places as possible (9 so far). That ability as already dramatically almost eliminated people signing up with odd IDs rather than their call sign. I didn’t need CSS to do that.
Jim
לייק 1
Can CSV invite lists (bulk invite, if you search for it) specify the username @techapj?
Ooops - click on “bulk invites from a file” and I don’t seem to be able to get out of it. File Open dialog box appears and no amount of cancelling will work - it keeps coming back.
Can’t even close the browser - it is going to have to be a Task Manager job to kill that.
No, CSV invite lists does not support specifying username, but Invite tokens does support pre-staging username:
3 לייקים
