Der Fehler tritt mit der iOS 26.1 (Beta 23B5044I) leider immer noch auf. Evtl. ist aber auch noch die jeweilige Discourse Beta-Version mitentscheidend.
Which error specifically?
Die vertikal versetzte Positionierung des Cursors im Eingabefeld, so wie z.B. hier beschrieben:
Thanks. I havenāt tested on iPad yet, will do so shortly. On iPhone, I can no longer repro.
The public 26.0.1 version is likely different from the beta 26.1.
I did test on iPad over the weekend and I couldnāt repro most of the big issues there with 26.1 (on the iOS beta/developer track).
Iām still running into the issue on iPad after installing iPadOS 26.0.1.
There seems to be a difference between using Discourse in a Safari tab, and when itās openend through a bookmark saved to the desktop, without the address bar.
Havenāt been able to repro the issue in the Safari tab.
When using the bookmark, it happens almost every time.
Not solved for 26.0.1 which was released yesterday, but is solved in iOS 26.1 which is in beta. Expected release in 4-5 weeks.
Iām still seeing the issue in iPadOS 26.1 as well.
When you scroll up the cursor jumps to the correct location, but it starts out too far down.
Any chance you can record your iPad screen to show this in action? I want to make sure I understand exactly what the reported issue is.
Thank you, I can reproduce the issue. It is indeed worse with the PWA (i.e. the bookmark saved via Add to Home Screen) vs directly on Safari.
Itās not an easy fix, but will give it a shot.
We have the same problem with our App in iOS26.1 Beta. I have tried a lot and wasnāt able to fix it yet. I think only Apple can fix this - make sure to file a report in https://feedbackassistant.apple.com/
Please tell me how you have fixed it if you can manage to do it.
I still canāt believe Apple shipped iOS26 with all the bugs.
