noahl
                    April 30, 2025, 12:38pm
                  1
              We have a certification program and want to allow users to join the certified group after confirming their certification ID.
The current idea:
Have a button in a plugin outlet
On click, open a modal for them to input their certification ID
Send the ID to the API, and display a message according to the result
Add them to the group if they’re verified
I want to understand if this is best suited as a Plugin or a Theme component since it’s dealing with API calls
              This is the full monty:
    Summary: Use Verifiable Credentials  to grant access to groups and badges in Discourse.
plugin installation guide .
But depends if your certification programme grants verifiable credentials …
                noahl
                    April 30, 2025, 12:51pm
                  3
              I think this might be a little different
It’s an in house system, rather than an exisiting platform if that makes any difference. Currently, it takes 2 pieces of info (the users email, and the ID) and will return the certifications they have completed
              You might get away with a User Field which are exposed on the API.
If not, you’ll need a plugin.
But you’ll need to work out who can see what.
If this is confidential to the User or it’s ok for others to see it etc.
See:
    The FAQ  isn’t crystal clear about this, so I want to get confirmation.
If I have a custom user field that is neither:
Show[n] on public profile
Show[n] on user card
Then it’s effectively private, visible only to the user, admins & moderators?
                noahl
                    April 30, 2025,  1:04pm
                  5
              Amazing!
So thinking out aloud here:
User field that is only visible to the user themselves (plus Admins etc)
Webhook when “user is updated” should contain contain the ID
Send the data to a “middle service” that can check the certification API, and then call the add to group Discourse API
Sounds like the most straight forward approach, rather than a plugin
