Is it possible to install discourse inside a directory?
I managed to install discourse successfully on the amazon EC2 free tier, using docker and was wondering if there is a way I can install it inside a directory, for instance example.com/forum
I would do forum.example.com but I use a .ga domain (freenom) as I’m only 15 and cannot afford domains and such and freenom does not support creating subdomains, which leaves me to use a directory
Thanks!
I think you want to read
