Is there a key shortcut to make search box disappear
We can invoke the search box by pressing forward slash ( / ), but we can only make it disappear by another shortcut (ctrl+alt+ f). Is it intentionally made so?
Even pressing ‘Esc’ doesn’t do so (which is most intuitive, I’d say).
I mean its far far easy to press forward slash to make it appear/disappear (than 3 keys together: Ctrl+ Alt+ f).
I agree that it makes sense to expect esc to close the search menu, as it closes the composer and other header menus. We should make that consistent.
I just tested this and it now behaves as expected! :raised_hands:
ctrl alt + f
esc
