Existe alguma maneira de editar o <header> em todo o site em um único local?
Hi, I noticed I can edit the header in each theme individually, but is there a way to edit it site wide in one place?
Like for adding the Facebook pixel, google tag manager, etc. I realize there’s a google tag manager plugin, but for the sake of this question I’m more interested in just editing the header in general and the best practices for doing that.
Thanks!
3 curtidas
Unless I didn’t understand your request, you can create your own theme component and add it to all your themes.
3 curtidas
Maybe I was asking wrong, but from what I can tell, the only place to edit the header aside from template edits is here:
But I’d essentially have to edit the header manually on every theme. If a site has a few dozen themes, it becomes cumbersome.
I was curious if there is a better way to edit the header globally where I only have to do it once.
1 curtida
So my suggestion is the way to go.
In Customize, go in Components, create a new theme component, edit its </head> content, and in the component settings, add it to all themes.
6 curtidas
Create a theme component. You can add it to all themes with a single click.
5 curtidas
Thanks @Canapin and @pfaffman. I did not realize this was possible. This easily solves my problem!
5 curtidas
