Is there a way to get full badge list for a user?
A user, kraml, is looking for a way to retrieve a full list of badges for a user through the API. Initially, kraml tried using the /users/<username>.json endpoint, but only received a limited list of badges. Mittineague suggested an alternative endpoint, https://meta.discourse.org/u/<username-here>/badges.json, but it yielded the same result.
Mittineague advised kraml to inspect the request URL in the browser’s dev tools when viewing a user’s badges page. This led kraml to discover the correct endpoint: https://meta.discourse.org/user-badges/<username>.json. The documentation for this endpoint is now available on docs.discourse.org, as confirmed by dax.
I’m evaluating integraton of the badge system into other part of a website. And I found in API document that it seems the only way to get a list of badge a user has it to use the /users/<username>.json API endpoint.
However after I tried this on myself on meta, I only saw three badges returned, the three that appears on my user card(are those called the featured badges?).
I searched in API document further more but didn’t see other API that returns badge information for a given user. Am I missing something or just that API don’t exist?
Try
Thanks but it returns the same payload as /users/<username>.json for me…
Hmm, I see what you mean. There was a recent change from “/users/” to “/u/” that may have something to do with it.
If you open your browsers dev tools and request a users badges page you should be able to see the URL that Discourse is using to get the page data. Is that different?
Thanks for the reminder. The API should be https://meta.discourse.org/user-badges/<username>.json.
Since the release of docs.discourse.org I was under the impression that all APIs are documented there. It seems this one is not yet.
Now it is documented for sure https://docs.discourse.org/#tag/Badges
