Isn’t that exactly what it looks like in your Discourse image? (Except in your editor import
and as
are bold)
Hi Alex,
I think @Moin has the right idea–I’m seeing some styling applied to the code blocks that looks like it’s probably coming from Custom CSS/HTML in the theme.
I think this line (font-family: Consolas;
) could be safely removed since it’s overriding these existing styles which use the same font but also specify fallback options:
code, pre {
font-family: var(--d-font-family--monospace);
:root {
--d-font-family--monospace: Consolas, Menlo, Monaco, "Lucida Console", "Liberation Mono", "DejaVu Sans Mono", "Bitstream Vera Sans Mono", "Courier New", monospace;
Maybe your computer isn’t able to display Consolas and is just falling back to the default (non-monospace) font. You can check here to see if that CSS is present:
Ah, I also just noticed we do have an official theme component for customizing code block appearance:
I think this was likely the issue but I didn’t verify. I ended up switching themes and it resolved the issue. Thanks, everyone, for your input! And thank you again, Bryce, for finding the theme component for customizing code block appearance.
