Problema con il caricamento dell'avatar durante l'importazione
HI,
I’m trying to import avatar for users. I do this in the punbb.rb import file:
create_users(results, total: total_count, offset: offset) do |user|
        { id: user['id'],
          email: user['email'],
          username: user['username'],
          created_at: Time.zone.at(user['created_at']),
          website: user['website'],
          registration_ip_address: user['registration_ip_address'],
          moderator: user['group_id'] == 4,
          admin: user['group_id'] == 1 ,
          post_create_action: proc do |newuser|
            origname=user['avatar_file']
            path='var/www/discourse/avatars'
            upload = create_upload(newuser.id, path, origname)
            if @upload
              newuser.create_user_avatar
              newuser.user_avatar.update(custom_upload_id: upload.id)
              newuser.update(uploaded_avatar_id: upload.id)
            else
              puts "Upload failed."
I’m noob regarding Ruby, I don’t understand where it doesn’t work. “Upload failed” even for user I know I have upload the correct file to ‘var/www/discourse/avatars’…
Thanks for your support
I think the error should be in the output. My guess is that the path is wrong. Perhaps you need a / at the start of the directory?
I tried, it didn’t work. Thanks :slight_smile:
I finally achieve the upload like this:
        { id: user['id'],
          #moderator: user['group_id'] == 4,
          #admin: user['group_id'] == 1 ,
            path=File.join("/var/www/discourse/avatars", user['avatar_file'])
            if File.exists?(path)
              upload = create_upload(newuser.id, path, File.basename(path))
              if upload.nil?
                puts "Upload failed. Path #{path} Id New #{newuser.id}"
              else
Thanks for the help and best regards! :slight_smile:
