自定义 OAuth 提供商问题:access_token 的 user_id 被设置为 nil
Hey everyone,
My company is starting to offer access to our discourse as part of our main product, and we decided to build a custom OAuth integration so people can login with the existing account.
We created as an authenticator based on FB and Twitter ones from Discourse codebase, released that as an internal Discourse plugin, and turned our main app into an OAuth provider. So far so good and everything worked just fine in development, but unfortunately I’m getting a PG constraint error in production.
Failed to handle exception in exception app middleware : PG::NotNullViolation: ERROR:  null value in column "user_id" violates not-null constraint DETAIL:  Failing row contains (XYZ, null, zk320lKJVI... : INSERT INTO "user_auth_tokens" ("auth_token", "prev_auth_token", "user_agent", "client_ip", "rotated_at", "created_at", "updated_at") VALUES (...
I’m assuming my plugin is passing something wrong to OmniauthCallbacksController. More precisely here:
  def complete_response_data
    if @auth_result.user
      user_found(@auth_result.user)
    elsif SiteSetting.invite_only?
      @auth_result.requires_invite = true
    else
      session[:authentication] = @auth_result.session_data
This is the code of my authenticator: honcho_authenticator.rb · GitHub
If someone has experience with the authenticator part of Discourse that could shed some light, that would be very helpful.
Thank you.
I found the error. I was expecting PluginStore to return a hash indexed by symbols but it’s actually index by strings. Doh!
Well, at least the code of my authenticator plugin can be useful to others.
Here’s my updated authenticator plugin in case someone else needs something similar:
