Jobs::HandledExceptionWrapper: Wrapped I18n::InvalidLocale for Jobs::UserEmail
Continuing the discussion from Failling jobs in Sidekiq : Jobs::UserEmail:
(I’m not convinced this is linked to the above, but the symptom was similar.)
After testing a group message to a group, I suddely got 2 of these retries alerted in Sidekiq with the error message Jobs::HandledExceptionWrapper: Wrapped I18n::InvalidLocale: "" is not a valid locale for the Jobs::UserEmail job.
Fortunately it’s not breaking anything critical, but worried it might be a problem if someone needs to send a group message. Any ideas?
2 curtidas
Assuming you are right up to date, it’s probably related to this:
This method should be changed to validate the locale against I18n.available_locales.
  def user_locale(user)
    user.respond_to?(:locale) ? user.locale : nil
1 curtida
Yeah I’m definitely up to the hour on tests-passed.
Can you check what locale returns for those users?
Should probably be
user.locale.present?, it is always going to respond
2 curtidas
If you can send me exactly what to run, I can try to get this for you; but as a non-dev I’m not sure what you need. The username blurred out was my own, if that helps. :slight_smile:
Thanks, I think it’s sorted out.
2 curtidas
This topic was automatically closed after 2 days. New replies are no longer allowed.
