Fóruns grandes com mais de 1 milhão de posts, como está o desempenho da sua busca?
Tivemos um recente influxo de usuários e um aumento no tráfego, o que resultou em mais pesquisas realizadas simultaneamente.
Estamos começando a ver timeouts de pesquisa em cerca de 1,2 milhão de posts.
O que fóruns maiores estão fazendo no que diz respeito à pesquisa? Vocês migraram para fora da funcionalidade de pesquisa central do Discourse ou ela ainda está performando bem? Talvez tenham atualizado o algoritmo de pesquisa/consultas para serem mais restritivos/específicos? Ajustes no banco de dados?
Obrigado pelos comentários!
1 curtida
What are your server specs and what resources seem most constrained?
I’m looking into potentially moving a board with about 20 million posts (public posts + private conversations) so I’m definitely interested in learning about potential performance issues with large boards.
1 curtida
It’s a long way from 1M posts to 20M posts, so there’s little advice that will apply to both of you. FWIW, I’ve got a site with 9M posts that has acceptable performance on a i7-7500U @ 2.7Ghz with 16GB of ram. There are a few other low volume sites on the same server.
A site using AWS database with 8GB of ram with 4M posts is having some struggle on searches especially.
@Jumanji, what are your server specs?
6 curtidas
11 curtidas
We’re on AWS. Forums are running on 4 instances, I believe t3.larges, so 4 vcpus and 16 GB ram. We’re running Kubernetes on a custom docker image. Our DB is on it’s own instance, m4.large, so 2 vcpus and 8 GB ram. The ram on the db instances could be the bottleneck for sure.
The queries that are timing out are generally more generic terms, single words. We’re had some run for greater than 60s. Now, we have also seen an influx of traffic to our website in the recent month. Last month, the month over previous month traffic jumped 40%. We also moved from v1.9 to v2.4 during that time, and I know since 1.9, Search has added the autocomplete search, so I assume that’s more load on the db server.
We did some query analysis and the following query was running anywhere from 20-60s:
`SELECT "posts".*
FROM "posts"
JOIN (
    SELECT *, row_number() over() row_number
    FROM (
        SELECT topics.id, min(posts.post_number) post_number
        FROM "posts"
        INNER JOIN "post_search_data" ON "post_search_data"."post_id" = "posts"."id"
        INNER JOIN "topics" ON "topics"."id" = "posts"."topic_id" AND ("topics"."deleted_at" IS NULL)
        LEFT JOIN categories ON categories.id = topics.category_id
        WHERE
            ("posts"."deleted_at" IS NULL)
            AND "posts"."post_type" IN (1, 2, 3)
            AND (topics.visible)
            AND (topics.archetype <> 'private_message')
            AND (post_search_data.search_data @@ TO_TSQUERY('english', '''a'':*ABD & ''price'':*ABD'))
            AND (categories.id NOT IN (SELECT categories.id WHERE categories.search_priority = 1))
            AND ((categories.id IS NULL) OR (NOT categories.read_restricted))
        GROUP BY topics.id
        ORDER BY
            MAX((
                TS_RANK_CD(
                    post_search_data.search_data,
                    TO_TSQUERY('english', '''a'':*ABD & ''price'':*ABD'),
                    1|32
                    CASE categories.search_priority
                    WHEN 2
                    THEN 0.6
                    WHEN 3
                    THEN 0.8
                    WHEN 4
                    THEN 1.2
                    WHEN 5
                    THEN 1.4
                    ELSE
                    CASE
                        WHEN topics.closed
                        THEN 0.9
                        ELSE 1
                        END
                    END
            )) DESC,
            topics.bumped_at DESC
        LIMIT 6
        OFFSET 0
    ) xxx
) x ON x.id = posts.topic_id AND x.post_number = posts.post_number
WHERE ("posts"."deleted_at" IS NULL)
ORDER BY row_number;
 Sort  (cost=495214.55..495214.56 rows=1 width=1177) (actual time=20529.725..20529.727 rows=6 loops=1)
   Sort Key: (row_number() OVER (?))
   Sort Method: quicksort  Memory: 29kB
   ->  Nested Loop  (cost=495164.08..495214.54 rows=1 width=1177) (actual time=20525.899..20529.703 rows=6 loops=1)
         ->  WindowAgg  (cost=495163.65..495163.80 rows=6 width=16) (actual time=20520.976..20521.078 rows=6 loops=1)
               ->  Limit  (cost=495163.65..495163.66 rows=6 width=24) (actual time=20520.969..20521.063 rows=6 loops=1)
                     ->  Sort  (cost=495163.65..495232.24 rows=27438 width=24) (actual time=20520.967..20520.969 rows=6 loops=1)
                           Sort Key: (max((ts_rank_cd(post_search_data.search_data, '''price'':*ABD'::tsquery, 33) * (CASE categories.search_priority WHEN 2 THEN 0.6 WHEN 3 THEN 0.8 WHEN 4 THEN 1.2 WHEN 5 THEN 1.4 ELSE CASE WHEN topics.closed THEN 0.9 ELSE '1'::numeric END END)::double precision))) DESC, topics.bumped_at DESC
                           Sort Method: top-N heapsort  Memory: 25kB
                           ->  GroupAggregate  (cost=493642.90..494671.83 rows=27438 width=24) (actual time=19082.214..20506.763 rows=32951 loops=1)
                                 Group Key: topics.id
                                 ->  Sort  (cost=493642.90..493711.50 rows=27438 width=400) (actual time=19082.184..19283.907 rows=191436 loops=1)
                                       Sort Key: topics.id
                                       Sort Method: external merge  Disk: 77632kB
                                       ->  Hash Left Join  (cost=36655.60..486646.69 rows=27438 width=400) (actual time=1562.696..18611.724 rows=191436 loops=1)
                                             Hash Cond: (topics.category_id = categories.id)
                                             Filter: (((categories.id IS NULL) OR (NOT categories.read_restricted)) AND (NOT (SubPlan 1)))
                                             ->  Gather  (cost=36645.63..486471.60 rows=58991 width=400) (actual time=1562.623..18249.349 rows=191436 loops=1)
                                                   Workers Planned: 2
                                                   Workers Launched: 2
                                                   ->  Nested Loop  (cost=35645.63..479572.50 rows=24580 width=400) (actual time=1556.547..18541.793 rows=63812 loops=3)
                                                         ->  Hash Join  (cost=35645.20..328688.61 rows=157831 width=25) (actual time=1551.912..13356.416 rows=285279 loops=3)
                                                               Hash Cond: (posts_1.topic_id = topics.id)
                                                               ->  Parallel Seq Scan on posts posts_1  (cost=0.00..286245.92 rows=504559 width=12) (actual time=0.280..11249.160 rows=404770 loops=3)
        Filter: ((deleted_at IS NULL) AND (post_type = ANY ('{1,2,3}'::integer[])))
        Rows Removed by Filter: 21884
                                                               ->  Hash  (cost=33938.80..33938.80 rows=92912 width=17) (actual time=1549.103..1549.103 rows=80351 loops=3)
        Buckets: 65536  Batches: 2  Memory Usage: 2557kB
        ->  Seq Scan on topics  (cost=0.00..33938.80 rows=92912 width=17) (actual time=0.010..1492.606 rows=80351 loops=3)
        Filter: ((deleted_at IS NULL) AND visible AND ((archetype)::text <> 'private_message'::text))
        Rows Removed by Filter: 216751
                                                         ->  Index Scan using posts_search_pkey on post_search_data  (cost=0.43..0.96 rows=1 width=383) (actual time=0.017..0.017 rows=0 loops=855836)
                                                               Index Cond: (post_id = posts_1.id)
                                                               Filter: (search_data @@ '''price'':*ABD'::tsquery)
                                                               Rows Removed by Filter: 1
                                             ->  Hash  (cost=9.43..9.43 rows=43 width=9) (actual time=0.059..0.059 rows=43 loops=1)
                                                   Buckets: 1024  Batches: 1  Memory Usage: 10kB
                                                   ->  Seq Scan on categories  (cost=0.00..9.43 rows=43 width=9) (actual time=0.007..0.045 rows=43 loops=1)
                                             SubPlan 1
                                               ->  Result  (cost=0.00..0.01 rows=1 width=4) (actual time=0.000..0.000 rows=0 loops=191436)
                                                     One-Time Filter: (categories.search_priority = 1)
         ->  Index Scan using index_posts_on_topic_id_and_post_number on posts  (cost=0.43..8.45 rows=1 width=1169) (actual time=1.435..1.435 rows=1 loops=6)
               Index Cond: ((topic_id = topics.id) AND (post_number = (min(posts_1.post_number))))
               Filter: (deleted_at IS NULL)
 Planning time: 3.508 ms
 Execution time: 20541.411 ms
(46 rows)`
1 curtida
Os your total database size less than 8GB? You will want to fit as much possible of your data in RAM.
Oh this will be slow. And a lot worse if the disk is a network mount.
Also check my reply above for tweaks.
8 curtidas
@Jumanji Could you please share some high traffic forums sites running on discourse, links please?
Traffic over millions.
I’m not part of the Discourse team, but I found this using search.
1 curtida
We’re at 24 GB. Definitely larger than the RAM available to the instance.
In some cases after massive moves running vacuum analyze can improve performance.
Also if you are on AWS are you using RDS? If not… why not?
5 curtidas
Thanks for that. Yup, we ran than and are on RDS.
17 posts were split to a new topic: Posting is taking multiple seconds
