בדיקות קלות של שינויים במחבר הפוסטים
(I’m not sure this is the right category, please correct me if this should go somewhere else?)
I was hoping to test some theme elements that affect the post composer on discourse.theme-creator.io. Understandably, the creator has posts disabled, so I was wondering if there was another good way to test my component on an instance with some real content. I could spin up a local instance and artificially populate it, but as that is a relatively heavyweight solution, I’d like to avoid doing that if possible.
You could install a copy of your default theme (rename it+set it for yourself) and add your theme component to that to check it out?
