We are setting up our new discourse internal environment and I was able to setup a custom URL scheme to link to an internal resource on the network, I wanted to add an easy button when making a new post which I was able to do but I want to be able to use the highlighted text for the link title as well as for the actual link itself. Right now I am just using an apply surround to insert what we need into a link but we have to manually change the link title, see the code below.
user enters 123456 > that applies this around the highlighted text [id_here](INET://123456)
I did look through the code but I could not find anything that would help me accomplish what we are looking to do. Is there anyway to use the highlighted text in the link title as well?
The protocol works fine, I can use inet:// as needed but I was just looking for an easy way for user to insert the custom URL into a post. In the previous form (phpbb) we made a custom bbcode for the link that worked however I was looking for an easier solution with discourse.
My suggestion was that rather than doing something so low level in the composer, “simply” modify the oneboxing subsystem so it formats inet:// links just like https:// links.
