Is there an API endpoint that can be called to get a list of all the reports? I’m currently manually going through the admin page and pulling the report names from each link, but was hoping for something I could use programatically.
1 me gusta
I do not believe there is one from what I can see - I don’t believe having looked at it that it is easy to pull the report data via the api.
You are able to pull some stats from the about.json if that helps.
We don’t have API endpoint support to get all available reports. The easiest way to get it is right click and copy the report links from admin dashboard. And add .json to the end of the URL.
6 Me gusta
Cool, thanks for confirming
1 me gusta
