I am receiving lots of this error in the log.
What could it be?
Check the tabs at the bottom, is it for the URL /topics/timings ? This just means some kind of network error between the user and the site, as if they were on mobile and lost the signal.
@sam we should probably suppress these, as there are a lot of them.. and they are meaningless.
Something weird is going on, we are getting CSRF issue on /posts/timing on meta which is an API we control.
Need to investigate cause the side effect of this error is that posts are not marked read.
Not sure what you mean, at the bottom I have this:
edit:
Clicking on an error, then env tab:
HTTP_HOST: rasando.it
REQUEST_URI: /topics/timings
REQUEST_METHOD: POST
HTTP_USER_AGENT: Mozilla/5.0 (Linux; Android 4.4.2; LG-D802 Build/KOT49I.D80220c) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.96 Mobile Safari/537.36
HTTP_ACCEPT: */*
HTTP_REFERER: http://rasando.it/t/marzo-2015/327/45
HTTP_X_FORWARDED_FOR: 87.1.235.67
HTTP_X_REAL_IP: 87.1.235.67
params:
timings: null
topic_time: 3238
topic_id: 327Share Protect
This topic has been created before:
https://meta.discourse.org/t/cant-verify-csrf-token-authenticity/25568?u=deanmarktaylor
I specifically mentioned this only occurs for mobile users for me:
https://meta.discourse.org/t/cant-verify-csrf-token-authenticity/25568/5?u=deanmarktaylor
I’ve also updated commented on stating my thoughts on why this happens:
https://meta.discourse.org/t/cant-verify-csrf-token-authenticity/25568/13?u=deanmarktaylor
