"Login by email" switches to incorrect strings when "hide email address" activated
A bug was reported where, when the hide email address taken setting is enabled, attempting to log in with an invalid email or username incorrectly displays a message indicating a match was found, instead of the expected ambiguous message. downey detailed the issue, noting the incorrect use of complete_email_found and complete_username_found strings. codinghorror initially questioned whether it was a bug, but downey clarified that the issue was the misuse of positive match messages when no match should be indicated. eviltrout provided a fix, which downey confirmed resolved the issue.
Reproduce:
  1. Enable the site setting hide email address taken, which is normally disabled, and described as “Don’t inform users that an account exists with a given email address during signup and from the forgot password form.”
  2. From a new browser session, attempt to log in :email: with email, and supply an invalid username, such as codinghorror.
Expected behavior
The error message text from one of the following strings apppears, not divulging the existince or non-existence of an account.
js.email_login.complete_email:
If an account matches codinghorror@example.com, you should receive an email with a login link shortly.
js.email_login.complete_username:
If an account matches codinghorror, you should receive an email with a login link shortly.
Actual behavior
The error message text incorrectly indicates that there was a positive match, even when there was no match.
js.email_login.complete_email_found:
We found an account that matches codinghorror@example.com, you should receive an email with a login link shortly.
js.email_login.complete_username_found:
We found an account that matches the username codinghorror, you should receive an email with a login link shortly.
Commentary
Although this works correctly for the “reset password” process, it seems the same logic should hold through with the login by email workflow.
I do not see this as a bug. The behavior is exactly as described above.
But if we have the other copy we should be using it in this scenario @eviltrout
Sorry if this was confusing. The bug as perceived, is that when (and only when) hide email address taken is set active, and non-matching values are entered for email-based login:
Instead of displaying the intentionally-ambiguous js.email_login.complete_email and js.email_login.complete_username strings, it instead (mistakenly) displays a false positive using strings js.email_login.complete_email_found and js.email_login.complete_username_found.
If the site setting is disabled (default) it correctly displays “no match found” strings.
This should fix it:
https://github.com/discourse/discourse/commit/ec21a15fa7234b8274b5b137afdd6dff78cf52a9
Yes, this looks correct now. Thanks! :trophy:
