Asoul
1
I’m new to discourse,
Is it possible validate the login process by customized database information?
I have an original service with login/logout mechanism,
now I want to create a forum by discourse, and login/logout from the original service’s user database
or what’s the keyword to search in discourse forum
Thanks
mpalmer
(Matt Palmer)
You want to look for “SSO”.
Asoul
4
@mpalmer
Can I just access to the DB for user authentication, not through the SSO in discourse?
I have no idea if this take a large effort or not.
Is there any example?
Thanks
mpalmer
(Matt Palmer)
5
If you’re asking what I think you’re asking, the answer is “no”.
You’d need to implement OAuth2 on your own system, then use:
Asoul
7
Hi @Tom_Newsom
I don’t know which one is a better choice: CAS or OAuth or others
As I know, OAuth can separate the resource permission and CAS can only check if login
Currently there is not so many resource to separate for OAuth, and seems CAS is simpler than OAuth (Is this correct?)
But if there is lots of resource in the future, I may need OAuth rather than CAS
What do you think?
Thanks
Well now we’re out of my comfort zone. I can’t help you here I’m afraid!
