Login redirect during sso provider login
On my site, lets say example.com, I have a link to my discourse site with a sso payload. For example discourse.com/session/sso_provider?sso=afjakfj&sig=sdjfsdkfj. After the user clicks this link, If the user is not logged on to Discourse, the user is first redirected to the discourse.com/login. When the user successfully enters their username and password, there is an ajax request in the background to the return_sso_url stored in the payload; the page then proceeds to redirect the user to the index of discourse.com. I expect the user to be redirected back to example.com.
For background see Using the Discourse SSO provider feature.
4 « J'aime »
@techAPJ can you give fixing this a shot, its a bit tricky but testable in an integration test
3 « J'aime »
Any progress here? @techAPJ
Okay, fixed this bug (finally!) :turtle:
Verified the code by testing against PHP scripts created by @paxmanchris (thanks!) :gift:
4 « J'aime »
