La connexion redirige vers la page d'accueil sans afficher d'erreur
I have a Discourse instance running which had SSO turned on. I got locked out due to misconfiguration.
Proceeded with changing a couple of settings:
./launcher enter app
rails c
SiteSetting.enable_sso = false
SiteSetting.enable_local_logins = true
exit
Trying to login directly shows no error and redirects to the home page. No errors are shown.
Also tried using the /users/admin-login.
Log output:
Started GET "/u/admin-login/490c222f04e33b2c59cc6fbdab2e7373" for <IP> at 2018-07-19 16:27:18 +0000
Processing by UsersController#admin_login as HTML
  Parameters: {"token"=>"490c222f04e33b2c59cc6fbdab2e7373"}
Redirected to http://<discourse address>
Completed 302 Found in 28ms (ActiveRecord: 7.0ms)
Started GET "/" for <IP> at 2018-07-19 16:27:18 +0000
Started GET "/" for <IP> at 2018-07-19 16:32:52 +0000
Processing by CategoriesController#index as HTML
Rendering categories/index.html.erb within layouts/application
Rendered categories/index.html.erb within layouts/application (1.3ms)
Rendered layouts/_head.html.erb (0.2ms)
Rendered common/_discourse_stylesheet.html.erb (0.1ms)
Rendered common/_special_font_face.html.erb (0.1ms)
Rendered application/_header.html.erb (0.1ms)
Rendered common/_discourse_javascript.html.erb (0.2ms)
Completed 200 OK in 93ms (Views: 6.4ms | ActiveRecord: 22.4ms)
Anything I’m missing?
When signing up for an account I get this error:
We cannot detect if your account was created, please ensure you have cookies enabled.
Is this on a local instance? Are you on our hosting? I’m confused.
This implies there is something going very awry with your browser or network. I suggest using a different web browser, one you don’t normally use?
This is a instance running in a EC2. Using this for staging purposes, which makes developing new integrations and updating the theme easier. Its mirroring our hosted instance we have with you.
Pretty sure I found out the reason, I’m accessing it directly by the IP Address, didn’t add a DNS record that points to it and didn’t configure Let’s Encrypt too.
Whats your thoughts?
@codinghorror
All good now. Added a DNS record and enabled Let’s Encrypt.
SSO working properly!
5 « J'aime »
This topic was automatically closed after 19 hours. New replies are no longer allowed.
