Looking for some good badges related to Voting
סיכום מבוסס בינה מלאכותית
The discussion revolves around creating badges related to voting on topics. Marc_Montecalvo initially shares ideas for badges, such as achieving a certain number of votes on a single topic or total votes across all topics, and asks for help with writing the queries. simon provides a link to a similar topic with a query that can be modified to achieve the desired result.
After some back-and-forth discussion, Marc_Montecalvo shares a query that partially achieves the desired result, but still needs refinement. codinghorror points out that these badges may be similar to existing default badges, but Marc_Montecalvo clarifies that the existing badges are not based on topic votes.
Ultimately, Marc_Montecalvo successfully creates a query that awards a badge to users who have a topic with at least 5 votes in a specific category, and shares the code for others to use.
I have a few ideas for badges but I’m unsure how to write the queries (I don’t know the table structure well enough). The numbers are just to use as a base. I’ll be extending them for additional badges.
  1. Someone got 10 votes on a single topic they wrote
  2. Someone got 20 votes total between all topics they wrote
  3. Someone voted 20 times
Anyone already have some badges like this and want to share? If not does anyone want to take a thwack at writing the queries?
The second query in this topic might do the trick: Badge ideas for Topic Voting. The query grants the badge to users who have cast a single vote, but there is a suggestion at the bottom of the query for how to require more votes to grant the badge.
Thanks @simon. I actually read over that post already but the query didn’t return the results I was expecting. It was the Limit 1 at the end messing me up. After removing that it works perfect for the “Someone voted x times”.
Any idea how to see how many votes a person got on a topic they wrote? Or how many likes they got total?
You might find some Data Explorer queries that you can modify to create badge queries. Have a look at the data explorer queries for topic voting and other sql-query and sql-triggered-badge topics.
Aren’t these rather similar to badges that already exist in Discourse?
That got me quite a ways towards my target:
select
    t.user_id,
    ucf.value,
    count(*)
from
    topics t
    join user_custom_fields ucf on t.id = cast(ucf.value as int)
where ucf.name = 'votes'
group by ucf.value, t.user_id
order by t.user_id, count(*) desc
That returns:
The two things I’m trying to get are total votes someone got and the topic that has the most votes for each person. You can see mmontecalvo has 2 topics showing. I’m fairly certain I need to use row_number() to get just the highest post but I don’t know how.
@codinghorror These may be similar to a default badge but none of the defaults are built off topics getting votes.
I think I got it! This will give the topic with the most votes per person that has at least 5 votes on it:
WITH query as (
select
    t.user_id,
    ucf.value,
    count(*) as num,
    t.created_at,
    row_number() OVER (PARTITION BY t.user_id order by count(*) desc) as rank
from
    topics t
group by ucf.value, t.user_id, t.created_at
having count(*) >= 5
order by t.user_id)
select user_id, value as topic_id, created_at granted_at
from query where rank = 1
I ended up going with this instead so we could give a badge for each topic someone puts in that gets at least X votes in the correct category:
WITH query as (
select
    t.user_id,
    ucf.value,
    count(*) as num,
    t.created_at
from
    topics t
where ucf.name = 'votes' and category_id = (
  SELECT id FROM categories WHERE name ilike 'UI Experience Requests'
order by t.user_id)
from query
