How did you make your Amazon Cloudfront SSL Work with Cloudflare ?
Hi @ashishdungdung,
Here is my settings:
- Cloudflare: setting SSL full (strict)
- Cloudfront SSL using Custom SSL Certificate ( ACM certificate )
Good luck!
You mentioned you are using Cloudfront SSl using custom SSL certificate , are you using a paid plan of cloudflare or free plan ?
Buy the way, have you heard about Cloudflare Origin CA ?
Sorry, I just hear about it.
