Coincidir espacios en la búsqueda con guiones bajos en el texto
When I searched for "enable local logins via email" (a site setting) an hour ago, I was surprised not to find a single post. Now I noticed that there actually are some posts containing enable_local_logins_via_email.
How about having search interpret spaces in a search term also as underscores, i.e. to return posts with enable_local_logins_via_email in a search for "enable local logins via email"?
8 Me gusta
Agree this will make searching for site settings much easier pr-welcome
5 Me gusta
I have added this feature FEATURE: Match spaces in search with underscores in text by majakomel · Pull Request #5690 · discourse/discourse · GitHub
I figured out that underscores are not escaped in exact term when searching "enable_local_logins_via_email", so it already matches variations with different word sepataratos like enable local logins via email or enable+local+logins+via+email, I assume this is intended?
With the change I added, spaces in the exact search term match the text where any word separators are used, not only underscores.
7 Me gusta
Does it also work for mixed separators within the same search term? (though I’m not sure I can come up with a realistic example for that)
You mean if searching for "enable local logins via email" matches "enable+local_logins via-email"? It does.
4 Me gusta
While we’re at it, I think it might also help if the search term with all dashes eliminated would be treated as equivalent with the search term. What I mean is: a search for “multi-site” should find multisite as if I had searched for “multisite”.
Maja I think that PR is a bit confusing, the change is actually required here:
Not for global search on the site. This is where we hit the issue regularly.
3 Me gusta
I original thought @tophee was referring to the Site Settings too, but it turns out it already supports searching with spaces:
https://github.com/discourse/discourse/commit/a78458300481a4e4505b829a30ef73d52fdf9b04
then I re-read the OP:
which led me to believe it is actually referring to /search page.
8 Me gusta
I think we should just table this for now, I don’t feel the original request has much utility.
3 Me gusta
Agree with you here. Removing pr-welcome from this.
My bad, I did not fully understand the request here and got confused, thanks @xrav3nz and sorry @maja
4 Me gusta
