Tema Material Design, gestione errata dei menu a discesa
This shows on other places too:
https://meta.discourse.org/c/meta/l/top
Isn’t this a problem with your chosen theme? I don’t see that in the default black or white themes.
1 Mi Piace
It’s in the material design theme by the looks. AFAIK one of the design guidelines for material was brightly colored high contrast top bars?
2 Mi Piace
Right, it’s the material design theme installed here on meta.
The problem is the extra drop shadows on the duration selector and the line below subcategories header, which ruin the “cards” effect.
1 Mi Piace
@rewphus can you have a look at this?
1 Mi Piace
Yeah, probably won’t be able to get to it until tomorrow though.
3 Mi Piace
Let me know if you need help, it’s select-kit related.
5 Mi Piace
Should be fixed now. It’s a very specific fix just ignoring the period-chooser-header, because the shadow seemed to work fine in other button dropdowns, so if you notice it anywhere else, let me know.
8 Mi Piace
