Math mode hard to use with rich text editor
I think that some basic math formatting that used to work no longer is on my site. For example, Greek characters \\alpha, \\Alpha, \\beta, \\Beta, \\delta, \\Delta, \\epsilon. I tried enabling asciimath and using percent signs rather than dollar signs, but that just produces something differently wrong. Is the plugin broken, or is there something else I should be doing?
These work:
 For example, Greek characters $\alpha,  \beta,  \delta, \Delta, \epsilon$.
For example, Greek characters \alpha, \beta, \delta, \Delta, \epsilon.
Looks like there are not upper case Alpha or Beta, though.
https://www.mathworks.com/matlabcentral/discussions/tips/847926-greek-alphabet-and-latex-commands-not-a-question
Thanks but even the lower-case ones are not currently working for me, though they used to. I’m including a screenshot of my math plugin settings below, along with a screenshot of what I put in a post and how it appears when posted… FWIW I’ve tried some other settings for the plugin, but nothing has fixed it. Am I doing something obviously wrong, or do you have any other suggestions?
It worked for me, but RTE doesn’t show as WYSIWYG, until that post is sended. Markdown shows right in preview.
Does it work when you use the markdown editor instead of the rich text editor?
I think @mcmcclur mentioned that math and the new rich text editor currently don’t work well together.
Not sure what I did wrong before (oh, they don’t have upper case for \Alpha or \Beta since “A” and “B” work), but these all seem to be working here, copied from your link with a bit of keyboard macro magic.
  • ALPHA: A, \alpha
  • BETA: B, \beta
  • GAMMA: \Gamma, \gamma
  • DELTA: \Delta, \delta
  • EPSILON: E, {\epsilon,\varepsilon}
  • ZETA: Z, \zeta
  • ETA: H, \eta
  • THETA: \Theta, {\theta,\vartheta}
  • IOTA: I, \iota
  • KAPPA: K, \kappa
  • LAMBDA: \Lambda, \lambda
  • MU: M, \mu
  • NU: N, \nu
  • XI: \Xi, \xi
  • OMICRON: O, o
  • PI: \Pi, {\pi,\varpi}
  • RHO: P, {\rho,\varrho}
  • SIGMA: \Sigma, {\sigma,\varsigma}
  • TAU: T, \tau
  • UPSILON: \Upsilon, \upsilon
  • PHI: \Phi, {\phi,\varphi}
  • CHI: X, \chi
  • PSI: \Psi, \psi
  • OMEGA: \Omega, \omega
- ALPHA: $     A,         \alpha  $
- BETA: $      B,         \beta $
- GAMMA: $     \Gamma,    \gamma $
- DELTA: $     \Delta,    \delta $
- EPSILON: $   E,         {\epsilon,\varepsilon} $
- ZETA: $      Z,         \zeta $
- ETA: $       H,         \eta $
- THETA: $     \Theta,    {\theta,\vartheta} $
- IOTA: $      I,         \iota $
- KAPPA: $     K,         \kappa $
- LAMBDA: $    \Lambda,   \lambda $
- MU: $        M,         \mu $
- NU: $        N,         \nu $
- XI: $        \Xi,       \xi $
- OMICRON: $   O,         o $
- PI: $        \Pi,       {\pi,\varpi} $
- RHO: $       P,         {\rho,\varrho} $
- SIGMA: $     \Sigma,    {\sigma,\varsigma} $
- TAU: $       T,         \tau $
- UPSILON: $   \Upsilon,  \upsilon $
- PHI: $       \Phi,      {\phi,\varphi} $
- CHI: $       X,         \chi $
- PSI: $       \Psi,      \psi $
- OMEGA: $     \Omega,    \omega $
But if the above doesn’t work on your site, then you have something wrong. As you see, it’s working here.
In your first example, you had double backslashes and in your second example, you’re using the visual editor (as someone else pointed out)
Thanks so much everyone.
It seems like the default editor was changed, which had the side effect of breaking mathjax.
I no longer get the preview pane, I guess because the main pane is now supposed to be WYSIWYG, which is not something I actually want.
Sadly, I don’t understand how to make this new editor go away. I see stuff at one of the links y’all provided about CSS but I don’t even know where I would put it, even if I understood it.
My site is managed by discourse.org, and I don’t think I have anything local… or is there some place I can access via settings that I can put it?
I’d like to banish the visual editor, get the preview pane back, and most importantly, get math formatting to work again.
Is there a straightforward way for me to do this?
@moin linked to it in the post before mine.
You can change the Default composition mode site setting to markdown.
And then if you are not using the starter plan, you can use the CSS from the post I linked in a theme component to hide the toggle in the composer. (Customizing themes without an Edit code button)
I’m trying to do this but it’s not working. I created a new component with the code:
.composer-toggle-switch {
display: none;
I don’t know if I need to do something else to make it active, but after doing this I still get the WYSIWYG editor, I don’t see anything to toggle that off (what would that look like, and where would I find it?), and the math in all of my previous posts is still broken.
I have to admit that I don’t actually know what a component is, I never do anything with CSS, etc. So I’m pretty clueless, sadly. But I would really like to get the math working on my site again. Suggestions?
Assuming that you put that in the correct place and enabled the component, that should hide the switch that allows you to change back and forth from the rich editor to the Markdown editor. In particular, the switch that I’ve circled that in this image of the left side of the editor should be gone:
Screenshot 2025-08-11 at 3.20.26 PM
You still need to change the Default Composition Mode in the site preferences. You should just be able to search for it.
Have you done this?
Thank you everyone for your patience on this
I had previously tried to change the default composition mode but didn’t find the setting – total failure on my part to be sure, in searching the settings. Anyway, I’ve now found it, and changed it, and I’m getting the markdown editor with preview again, which is awesome.
Even better, now my math works!
FWIW I didn’t know what the toggle looked like or where to find it, so I didn’t know how to switch it manually. Thanks @mcmcclur especially for that screenshot.
On the component, I think it is enabled, but for some reason not working, but now I’m not even sure it matters much to me. Am I right that this is just for hiding the mode toggle? I’m not sure I actually care whether or not people can toggle the mode, as long as it’s possible to make the math work, and especially since it will work in the default mode.
Yes, that’s exactly correct. I described here why that matters to me but it’s arguably more natural to let the user decide in most cases.
Thanks again to everyone here – you’ve been super helpful and I really appreciate it.
PS I figured out why the toggle wasn’t being hidden. The component was not set to apply to the correct theme. Now I can hide it, and I’ll figure out whether or not I really want to. Thanks again!
