MathJax Not Rendering Inside <details> Without Newline After <summary>
Hi — this is a follow-up to my earlier post:
I’ve identified that MathJax expressions inside <details> blocks do not render unless a newline is inserted immediately after the <summary> tag.
Minimal reproduction:
This does not render:
<details><summary>Example</summary>
x^2 + y^2 = z^2
</details>
This does render:
x^2 + y^2 = z^2
</details>
Notes:
  • This behavior is unintuitive and undocumented.
  • It affects both inline and block MathJax.
  • ChatGPT tells me it “Tested on Discourse 3.2.0beta3 with default settings”.
Could this be made more robust or documented somewhere for users relying on math formatting?
You wouldn’t have this problem if you were using details block which is the recommended way:
[details="Example"]
x^2 + y^2 = z^2
[/details]
ah, it’s probably best to not fix this topic then
it’s ChatGPT that needed fixing :rofl:
Yeah this is not a bug, its a limitation/design of CommonMark
Mixing HTML and Markdown has some very specific and somewhat surprising rules.
