In my installation of Discourse, MathJax is broken. I think that’s probably due to “Could not find module discourse/lib/load-script”. Things were working, and I cannot be sure when they broke, but I suspect it happened when I upgraded to Discourse to 1.2.1 and MathJax to 0.4.1.
This is the full error message I’m seeing with Chrome:
To fix this, I tried:
- Double checking I’m up-to-date on everything.
- disabling and reenabling the MathJax plugin.
- Rebooting, naturally.
- launch app rebuild
What else might I try?
I think the install is pretty standard. I followed the instructions to install with Docker on DigitalOcean from before the 1.0 release, and I’ve always upgraded via the Admin panel since then.
If needed, the issue can be seen here.
