Mini_racer 在最新发行版中破坏构建
So I tried upgrading Discourse today and it failed due to mini_racer. I’m hosting this on Bitnami, which I know you don’t support, but this doesn’t seem to be a Bitnami thing as it crashes even when I just install it on it’s own with:
gem install mini_racer -v '0.2.4' --source 'https://rubygems.org/'
However, I noticed that mini_racer is at 0.2.5 as of 21 hours ago…but all of the latest releases are over 2 days ago. If I edit the gemfile.lock to force 0.2.5 with:
mini_racer (~> 0.2.5)
Discourse will complain that it can’t build because the file has been edited:
You are trying to install in deployment mode after changing
your Gemfile. Run `bundle install` elsewhere and add the
updated Gemfile.lock to version control.
The dependencies in your gemfile changed
You have added to the Gemfile:
* mini_racer
You have deleted from the Gemfile:
* mini_racer (~> 0.2.5)
I think if I can fix this error then the problem will go away, but I don’t understand what it means to bundle install elsewhere?
And here’s the full error log when I run:
ERROR LOG
Fetching: libv8-7.3.492.27.1-x86_64-linux.gem (100%)
Successfully installed libv8-7.3.492.27.1-x86_64-linux
Fetching: mini_racer-0.2.4.gem (100%)
Building native extensions. This could take a while...
ERROR:  Error installing mini_racer:
        ERROR: Failed to build gem native extension.
    current directory: /opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/mini_racer-0.2.4/ext/mini_racer_extension
/opt/bitnami/ruby/bin/ruby -r ./siteconf20190426-939-18bpxj.rb extconf.rb
checking for -lpthread... yes
creating Makefile
make "DESTDIR=" clean
make "DESTDIR="
compiling mini_racer_extension.cc
cc1plus: warning: command line option ‘-Wimplicit-int’ is valid for C/ObjC but not for C++
mini_racer_extension.cc: In function ‘void prepare_result(v8::MaybeLocal<v8::Value>, v8::TryCatch&, v8::Isolate*, v8::Local<v8::Context>, EvalResult&)’:
mini_racer_extension.cc:234:73: error: no matching function for call to ‘v8::Value::ToObject()’
                        String::NewFromUtf8(isolate, "JSON"))->ToObject();
In file included from mini_racer_extension.cc:4:0:
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2390:44: note: candidate: v8::MaybeLocal<v8::Object> v8::Value::ToObject(v8::Local<v8::Context>) const
  V8_WARN_UNUSED_RESULT MaybeLocal<Object> ToObject(
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2390:44: note:   candidate expects 1 argument, 0 provided
In file included from /opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8-internal.h:13:0,
                from /opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:25,
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2404:35: note: candidate: v8::Local<v8::Object> v8::Value::ToObject(v8::Isolate*) const
                    Local<Object> ToObject(Isolate* isolate) const);
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8config.h:329:48: note: in definition of macro ‘V8_DEPRECATE_SOON’
#define V8_DEPRECATE_SOON(message, declarator) declarator
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2404:35: note:   candidate expects 1 argument, 0 provided
mini_racer_extension.cc:239:58: error: no matching function for call to ‘v8::Value::ToObject()’
            Local<Object> object = local_value->ToObject();
mini_racer_extension.cc:267:101: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::String>)’
                len = snprintf(buf, sizeof(buf), "%s at %s:%i:%i", *String::Utf8Value(message->Get()),
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2857:5: note: candidate: v8::String::Utf8Value::Utf8Value(v8::Isolate*, v8::Local<v8::Value>)
    Utf8Value(Isolate* isolate, Local<v8::Value> obj);
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2857:5: note:   candidate expects 2 arguments, 1 provided
mini_racer_extension.cc:268:94: error: no matching function for call to ‘v8::Value::ToString()’
                                *String::Utf8Value(message->GetScriptResourceName()->ToString()),
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2386:44: note: candidate: v8::MaybeLocal<v8::String> v8::Value::ToString(v8::Local<v8::Context>) const
  V8_WARN_UNUSED_RESULT MaybeLocal<String> ToString(
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2386:44: note:   candidate expects 1 argument, 0 provided
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2402:35: note: candidate: v8::Local<v8::String> v8::Value::ToString(v8::Isolate*) const
                    Local<String> ToString(Isolate* isolate) const);
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2402:35: note:   candidate expects 1 argument, 0 provided
mini_racer_extension.cc:269:55: error: no matching function for call to ‘v8::Message::GetLineNumber()’
                                message->GetLineNumber(),
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:1623:36: note: candidate: v8::Maybe<int> v8::Message::GetLineNumber(v8::Local<v8::Context>) const
  V8_WARN_UNUSED_RESULT Maybe<int> GetLineNumber(Local<Context> context) const;
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:1623:36: note:   candidate expects 1 argument, 0 provided
mini_racer_extension.cc:284:38: error: no matching function for call to ‘v8::TryCatch::StackTrace()’
            if (!trycatch.StackTrace().IsEmpty()) {
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:8890:43: note: candidate: v8::MaybeLocal<v8::Value> v8::TryCatch::StackTrace(v8::Local<v8::Context>) const
  V8_WARN_UNUSED_RESULT MaybeLocal<Value> StackTrace(
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:8890:43: note:   candidate expects 1 argument, 0 provided
mini_racer_extension.cc:286:71: error: no matching function for call to ‘v8::TryCatch::StackTrace()’
                evalRes.backtrace->Reset(isolate, trycatch.StackTrace()->ToString());
In file included from /opt/bitnami/ruby/include/ruby-2.5.0/ruby.h:33:0,
                from mini_racer_extension.cc:2:
mini_racer_extension.cc: In function ‘VALUE convert_v8_to_ruby(v8::Isolate*, v8::Local<v8::Context>, v8::Local<v8::Value>)’:
mini_racer_extension.cc:366:39: error: no matching function for call to ‘v8::Value::Int32Value()’
      return INT2FIX(value->Int32Value());
/opt/bitnami/ruby/include/ruby-2.5.0/ruby/ruby.h:233:33: note: in definition of macro ‘RB_INT2FIX’
#define RB_INT2FIX(i) (((VALUE)(i))<<1 | RUBY_FIXNUM_FLAG)
mini_racer_extension.cc:366:13: note: in expansion of macro ‘INT2FIX’
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2427:40: note: candidate: v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const
  V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2427:40: note:   candidate expects 1 argument, 0 provided
mini_racer_extension.cc:370:46: error: no matching function for call to ‘v8::Value::NumberValue()’
      return rb_float_new(value->NumberValue());
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2422:39: note: candidate: v8::Maybe<double> v8::Value::NumberValue(v8::Local<v8::Context>) const
  V8_WARN_UNUSED_RESULT Maybe<double> NumberValue(Local<Context> context) const;
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2422:39: note:   candidate expects 1 argument, 0 provided
mini_racer_extension.cc:411:41: error: no matching function for call to ‘v8::Value::ToObject()’
  Local<Object> object = value->ToObject();
mini_racer_extension.cc:434:42: error: no matching function for call to ‘v8::Value::ToString()’
    Local<String> rstr = value->ToString();
In file included from /opt/bitnami/ruby/include/ruby-2.5.0/ruby/ruby.h:29:0,
                from /opt/bitnami/ruby/include/ruby-2.5.0/ruby.h:33,
mini_racer_extension.cc:435:50: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::String>&)’
    return rb_enc_str_new(*String::Utf8Value(rstr), rstr->Utf8Length(), rb_enc_find("utf-8"));
/opt/bitnami/ruby/include/ruby-2.5.0/ruby/defines.h:105:53: note: in definition of macro ‘RB_GNUC_EXTENSION_BLOCK’
#define RB_GNUC_EXTENSION_BLOCK(x) __extension__ ({ x; })
mini_racer_extension.cc:435:12: note: in expansion of macro ‘rb_enc_str_new’
mini_racer_extension.cc:435:70: error: no matching function for call to ‘v8::String::Utf8Length()’
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2536:7: note: candidate: int v8::String::Utf8Length(v8::Isolate*) const
  int Utf8Length(Isolate* isolate) const;
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:2536:7: note:   candidate expects 1 argument, 0 provided
/opt/bitnami/ruby/include/ruby-2.5.0/ruby/defines.h:105:57: error: void value not ignored as it ought to be
/opt/bitnami/ruby/include/ruby-2.5.0/ruby/encoding.h:150:39: note: in expansion of macro ‘RB_GNUC_EXTENSION_BLOCK’
#define rb_enc_str_new(str, len, enc) RB_GNUC_EXTENSION_BLOCK( \
mini_racer_extension.cc: In function ‘v8::Local<v8::Value> convert_ruby_to_v8(v8::Isolate*, VALUE)’:
mini_racer_extension.cc:515:73: error: no matching function for call to ‘v8::Date::New(v8::Isolate*&, double)’
            return scope.Escape(Date::New(isolate, NUM2DBL(value) * 1000));
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:5185:50: note: candidate: static v8::MaybeLocal<v8::Value> v8::Date::New(v8::Local<v8::Context>, double)
  static V8_WARN_UNUSED_RESULT MaybeLocal<Value> New(Local<Context> context,
/opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/libv8-7.3.492.27.1-x86_64-linux/vendor/v8/include/v8.h:5185:50: note:   no known conversion for argument 1 from ‘v8::Isolate*’ to ‘v8::Local<v8::Context>’
mini_racer_extension.cc: In function ‘VALUE rb_snapshot_load(VALUE, VALUE)’:
mini_racer_extension.cc:557:32: error: ‘CreateSnapshotDataBlob’ is not a member of ‘v8::V8’
    StartupData startup_data = V8::CreateSnapshotDataBlob(RSTRING_PTR(str));
mini_racer_extension.cc: In function ‘VALUE rb_snapshot_warmup_unsafe(VALUE, VALUE)’:
mini_racer_extension.cc:588:37: error: ‘WarmUpSnapshotDataBlob’ is not a member of ‘v8::V8’
    StartupData warm_startup_data = V8::WarmUpSnapshotDataBlob(cold_startup_data, RSTRING_PTR(str));
mini_racer_extension.cc: In function ‘VALUE convert_result_to_ruby(VALUE, EvalResult&)’:
mini_racer_extension.cc:767:48: error: no matching function for call to ‘v8::Value::ToString()’
            Local<String> rstr = tmp->ToString();
mini_racer_extension.cc:768:71: error: no matching function for call to ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::String>&)’
            VALUE json_string = rb_enc_str_new(*String::Utf8Value(rstr), rstr->Utf8Length(), rb_enc_find("utf-8"));
mini_racer_extension.cc:768:33: note: in expansion of macro ‘rb_enc_str_new’
mini_racer_extension.cc:768:91: error: no matching function for call to ‘v8::String::Utf8Length()’
At global scope:
cc1plus: warning: unrecognized command line option ‘-Wno-self-assign’
cc1plus: warning: unrecognized command line option ‘-Wno-constant-logical-operand’
cc1plus: warning: unrecognized command line option ‘-Wno-parentheses-equality’
Makefile:209: recipe for target 'mini_racer_extension.o' failed
make: *** [mini_racer_extension.o] Error 1
make failed, exit code 2
Gem files will remain installed in /opt/bitnami/ruby/lib/ruby/gems/2.5.0/gems/mini_racer-0.2.4 for inspection.
Results logged to /opt/bitnami/ruby/lib/ruby/gems/2.5.0/extensions/x86_64-linux/2.5.0-static/mini_racer-0.2.4/gem_make.out
I upgraded mini_racer today cause it is overdue and super nice to be on Chrome 73 vs 67 that said you are totally playing with fire here.
This indicates to me you have an install that is not leaning on our Gemfile.lock, all sorts of sad can happen.
Is there are reason you are not on our official docker image?
4 个赞
Yeah I’m just going to go with the docker image :sweat_smile:
I had a few extra Google Cloud Credits and at the time the only way I thought I could get Discourse going was through their Bitnami one-click install. I was definitely wrong so I’ll be moving over to the docker image soon
4 个赞
