Missing logo in email summary
Hi all,
The logo in our digest emails seems to be broken, even though it displays correctly in the
digest logo section of the settings.
When the digest logo is removed and it should fall back to logo this is also broken in the final and test emails.
We use AWS. All other images are working correctly on our forum (community.lpma.com)
Here is the log from /logs, not sure if these two entries are relevant
Thanks!!
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/dynamic_matchers.rb:22:in `method_missing'
/var/www/discourse/app/controllers/metadata_controller.rb:43:in `default_manifest'
/var/www/discourse/app/controllers/metadata_controller.rb:6:in `manifest'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in `process'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/conditional_get.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:214:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.3.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.2.0.pre.1/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:180:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'
I believe you were looking at something related to this @tgxworld? Maybe having to do with the image handling changes in site settings?
Can you try moving to tests-passed and running
cd /var/discourse
./launcher rebuild app
From what I can see short_title is definitely defined on the SiteSetting object
Hey @sam, i’m not quite technical enough to know how to do this on my end right now. Is there anything else I can do to help diagnose? If not i’ll see if I can get a developer me run that. We’ve had one user report that they aren’t receiving any digest emails also, not sure if related.
I confirm the OP’s problem for Meta and my own Discourse too.
Here are screenshots from my Gmail and Mail app on MacOS and iPhone respectively.
Screenshots for Meta
Gmail on Safari (MacOS)
Mail app of MacOS
Gmail app on iPhone
Below are details for my own Discourse forum after ./launcher rebuild app
Screenshot for my own Discourse Forum
Gmail app on iPhone
Don’t know if other can see the e ail logo for meta. I would like to know of that’s on my end only.
I did a ./launcher rebuild app yesterday.
The issue has been fixed in today’s update:
I believe @tgxworld just fixed this a few hours ago?
O yes this has been fixed in
https://github.com/discourse/discourse/commit/27c793a192ea0443373dc65517b50dfa21480441
