Missing Open Graph og:type
In a discussion titled ‘Missing Open Graph og:type’ under the Feature category, bifftannen reports that their site’s Open Graph validation fails due to the missing og:type tag, despite the spec defaulting to website if omitted Falco. bifftannen asks for a roadmap, emphasizing the small effort vs. large impact—particularly for SEO and Ahrefs audit scores. codinghorror questions the necessity, noting the default is valid. bifftannen clarifies that og:type is considered required by validation tools and impacts search ranking. JoshuaH shares a workaround: manually adding the tag via theme customization, which resolves validation. guidoleenders confirms adding the tag boosted their Ahrefs audit score from 54% to 74%. bifftannen reiterates the desire for a built-in fix in the next release. Falco closes the thread by linking to a commit that implements the fix: https://github.com/discourse/discourse/commit/f36ecf86f8bc2fe42fda5107663af9d0ae3924e8.
Hi,
When checking the Open Graph validation for the site, it seems to be missing the “og:type” field.
How can we add this?
Thanks
Peter
Per the spec a missing type should be parsed as og:type=website, which is what we would end up using.
Any non-marked up webpage should be treated as og:type website.
But I guess it doesn’t hurt to be specific? pr-welcome
Do you have some sort of roadmap, where we can see when this is planned?
I feel like this is a very minor thing, but something that would have a large impact for us.
Thanks
Peter
Can you explain exactly how it would have a large impact? If the value is missing, the default is correct, per above. Specifying the value of something that is already valid by default doesn’t seem like a good use of our engineering time.
First of all, thank you for a very cool product, we really like it.
But I’m a bit unsure what you mean?
From what I can understand (and I may very well be wrong), the four required Open Graph tags for every page are og:title , og:type , og:image , and og:url .
But the og:type is missing, which is causing our Open Graph validation to fail. It just seems to be a very small thing to add. Adding this would, in our case, improve our ranking search wise and then drive more trafic to our community.
I ended up adding the tag manually to the <head>: Settings > Customize > Select theme > Edit CSS/HTML > “</head> tab”
Seems to be validating now!
Adding it increased the audit ranking of our forums on Ahrefs from 54% to 74%.
Its exactly our ahrefs validation that fails. We can add it manually as suggested by @JoshuaH, but it just seems like such a small thing to fix, so it would be nice to have in the next release.
Thanks
Peter
This should solve it
This topic was automatically closed after 16 hours. New replies are no longer allowed.
