Monospace font in the Markdown-only editor
I’m still undecided whether I find monospace necessary or not, but the updated font is a clear improvement over the previous one (in contrast the previous situation, I tend to say, now it could be slightly larger again).
But in any case, it’s nice that the good old ASCII art can make a return now :slightly_smiling_face:
| LONG LIVE |
| THE BUNNY |
(\__/) ||
(•ㅅ•) ||
/   づ
I mentioned this earlier in the topic, we need the change to breath for a bit longer, lets give it at least another week.
The answer here is absolutely maybe. Keep the feedback coming, good or bad, we are reading it all.
One issue I am battling with internally is the targeting of different “personas”/“audiences”
  1. General public → just use “rich composer” 99% of the time, none of this is an issue
  2. Highly technical users → just use “raw markdown” - generally used to this type of view and many happy with the change
  3. Non technical BUT do not want to use rich editor → monospace irks them - eg: @Jagster - prefer a different font
It is a tricky problem, we are always reticent to add more user settings, but I do acknowledge that there is something here, I just want to see how we feel in a week.
I was trying to figure out different non-intrusive visual cues, but it’s tough. :sweat_smile:
The only one that seems acceptable is a label somewhere, like:
A Slack interface shows a new post creation window within the "Announcements" channel, suggesting the user can type a title or paste a link. (Captioned by AI)
And maybe with a color change to help better the visual memory:
The image shows a new topic modal window within a forum interface, where a user can create a topic with an optional title and tags. (Captioned by AI)
It’s pretty visible without being intrusive. It has its share of cons, for sure. It takes some space, but it’s okay in the context of a temporary transition. I’m not 100% convinced, but it seems like an interesting alternative. I just wanted to share the idea. (feel free to open the gifs in a new tab to see in full size; it misses a fullscreen button)
this for some reason is one of the best arguments against I’ve heard so far. I just had to go check the font in my VS code editor, so see, I am a coder. I had a code editor open on my desktop, and sure enough, it is a mono-space font. I never even noticed. But for some reason, it just feels weird here and my own instance. I’ll give it a week, like Sam is asking, change is jarring, maybe in a week I won’t even notice.
I agree. I just wrote a really long post, and honestly the monospace font is giving me a headache. I proofread my posts very thoroughly, and I tend to go back and forth between reading the raw markdown and reading the formatted post while doing so. Now it’s very difficult to do so in the editor section.
I also generally don’t like WYSIWYG. In my experience they are very janky, and I have no intention of using it. So for me, the markdown editor that has existed forever needs to continue to be a smooth user experience.
I agree with @schneeland. I’m a software engineer and regularly use IDEs that of course use monospace font, but this is simply a different context. It would indeed be very jarring if Jira started using a monospace font.
I’m not sure I’ve ever had a problem working with tables in markdown. And besides, even in monospace the vertical bars between each column won’t align since each cell is likely to have a different number of characters in it.
In any case, I know you want to let the change breathe a bit, but hopefully this feedback helps. Note that my comments are based on the most recent monospace font and I didn’t see the previous version. So I’m only comparing my experience to the one that has existed for years, not to the first monospace font used a couple days ago.
How many people will actually use tables on a forum reply that justifies this? Also, Obsidian uses markdown and uses tables with monospace inside, while the text outside it sans-serif:
I don’t see why the whole composer has to change to monospace when they could co-exist?
I would say 99% of what we write is “normal” text, not markdown.
My honest opinion is that this is not a great feature to be “forced” on users, even if we let it breathe. It’s not a change that users are relieved to have, and that’s visible in most comments. It should be a user preference.
I don’t really see any issue with the composer having the same typeface as the preview. It’s pretty easy to understand what’s happening. It’s been for many years, right? “If it’s not broken, don’t fix it”, they say. And it applies here, I believe.
For people struggling with this change, one recommendation I have is:
Give it a shot for a few days with preview disabled
Once preview is disabled the font change feels significantly more natural.
  • Swapping from Rich to Source code feels a lot more natural
  • It is extremely clear what mode you are in
We are still taking feedback, nothing is 100% set in stone, we may add more user toggles here, I don’t know.
This font should be configurable under https://<site>/admin/config/fonts, but isn’t currently.
I didn’t like the monospaced font (it’s good for coding but not for typing in a forum) so I changed it back by adding this CSS to my theme (let me know if there is a better way of doing this please!)
.d-editor-container--rich-editor-enabled .d-editor-textarea-wrapper textarea.d-editor-input {
    font-family: var(--font-family) !important;
    font-size: var(--base-font-size) !important;
    line-height: var(--line-height-large) !important;
I really think this should be a user setting. I shouldn’t be forced to use the wysiwyg view to use a readable font. Monospace fonts are basically unreadable to me for normal (non-code) text. This is especially glaring on mobile where you can’t see a preview at the same time side by side, but it’s still not great on desktop. I don’t think a site setting or CSS override is sufficient since not all site admins will respond to user feedback for stuff like this.
Absolutely (and I agree strongly enough to have created an account for the purposes of posting agreement!)
Markdown automatically word-wraps lines and has other properties that blurs the line between “word processing” and “code”. On a discussion forum, it’s certainly much more a word processor…and I’ve been quite happy with the historical behavior. I’ve appreciated being able to freely copy and paste without ambiguity. I like being able to hit enter and get a newline, instead of some WYSIWYG imagination of what I might have meant.
Markdown editing does not become more functional or enjoyable by using a fixed-width font. It gets worse…and I’d think anyone who actually uses it would agree.
So Markdown is being made a second-class citizen, for the purpose of strengthening the visual cue of which mode you’re in.
I’d ask the UX designers among you if there’s a better way to emphasize the mode… that doesn’t ask you to make the nearly-never-good tradeoff of using a fixed width font to edit what is mostly non-code text.
If a good answer to that were found, there’d be no need for an option to toggle fixed-width vs. non, because it would always be a proportional font.
2 valid points!
A lot of time has passed since we were told to “let it breathe”. As we can see, this change is not something we all said “amazing change!”
As someone else said, was there a tremendous demand for this? I don’t know… I doubt it, but maybe I’m wrong.
I think that looking at markdown as a “coding” language to justify the monospace, doesn’t make much sense to me. I see markdown as a way to format text, not necessarily a “coding” language. I don’t have to be a developer to use markdown, unlike using for example VS Code, Cursor, etc, where monospace is appropriate.
When we are creating new topics or replies in a forum, we are not “coding” we are “texting” and text should be readable. Monospace, just isn’t that readable. I can type a 150 paragraph in a markdown editor without ever using any markdown “syntax” (if that’s what it’s called?). So I see markdown as an extra thing we can use to format text, not necessarily a “format” where everything has to sit on, if that makes sense?
Add this in your CSS @seanblue & @alltiagocom. It’ll revert the composer back to your site’s default.
/* Changes the font in the composer from monospace back to the san-serif default */
.d-editor-container .d-editor-textarea-wrapper textarea.d-editor-input {
    font-family: var(--font-family);
    font-size: 1rem; /* or use 16px, or your specific default size */
I believe in giving users a preference. Maybe some users want monospace. I don’t know. I’ve seen some crazy VS Code themes (green background with black text, or worse), and I would never use that, but each person is different.
I’m definitely changing mine to sans-serif, but my point here is that we could offer the options to our users. That’s all. Some users want markdown with monopace, some with sans-serif. Some users don’t care about markdown and only want rich text. Having those options natively would be a better option, in my opinion.
I’m biased as a Discourse employee, but I much much prefer the new monospace font. So there’s a good chance that the people that go “ah yeah, nice” or even “huh, never noticed” don’t speak up.
There must be dozens of us at least :smiley:
Sure. Out there is a lot of coders and devs :joy:
(But among ordinary people monospace isn’t counted as a readable font. For me and my users the CSS-trick did the job, so for me as an admin this is more an academic question. But let’s stop to say this change is done for majority and is widely in use, because that isn’t true.)
I think you’re making assumptions about me that aren’t true :slight_smile:
I agree - the monospace is unexpected and ugly. Also unnecessary. There’s already a slider in the toolbar which tells us which mode we’re in.
Well, I didn’t, because everything wasn’t about or by you.
Anyway. Keeping two options as a composer was a wonderful solution. Monospace not that much, but as long as the CSS change works, I’m happy. But I understand the point of having a user setting for that — but I don’t like it, because there is already quite a bit to set up. But I’m not so sure how many ordinary users ever even change settings… and then it doesn’t matter how crowded it is :man_shrugging:
