Multisite rebuild fails on AlmaLinux 9.2, works on AlmaLinux 8.8
I’ve been testing a multisite version (splitting two forums into separate databases) on my testbed server and it works great there (AlmaLinux 8.8.)
But when I try it on AlmaLinux 9.2 on my production server, the rebuild fails.
Some excerpts from the log:
I, [2023-08-18T22:33:25.200147 #1]  INFO -- : > cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
rake aborted!
TypeError: no implicit conversion of Symbol into Integer
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:183:in `[]='
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:183:in `block in load_config!'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:181:in `each'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:181:in `load_config!'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:173:in `initialize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:40:in `new'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/connection_management.rb:40:in `config_filename='
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rails_multisite-5.0.0/lib/rails_multisite/railtie.rb:19:in `block in <class:Railtie>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.7/lib/rails/application.rb:372:in `initialize!'
/var/www/discourse/config/environment.rb:7:in `<main>'
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate failed with return #<Process::Status: pid 884 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params "cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate"
Any suggestions?
Your host version should not be making any difference here.
I would start with going over your multisite.yml with a fine comb and ensuring it’s the same in both places.
I thought I had updated the app.yml file to match the changes I made on the testbed server, but apparently not. When I copied that app.yml file over and changed the domain information, the app built successfully. Still a few other issues to deal with, but they’re not Discourse issues.
