Perfect, thanks for that @sam. Giving people theme choice on every device is the goal.
Is that wording clear enough? To me, Make this my default theme sounds like it wouldnât affect devices where the theme was already changed locally.
Even after reading your example, Iâm not totally sure how this checkbox works⌠(Is its state saved to the server? If I uncheck it on one device, will it become unchecked on all other devices as well?)
It is tied to the save action. The text is quite clear to me. At the time of save, either:
- you change theme for your current device only
Or
- you change theme for all your devices
There seems to be a bug with the theme selector - I believe this is a browser with a theme I previously selected without âmake this my default theme everywhere.â
Here, Iâm selecting a dark theme, applying, then navigating away with the new theme (supposedly) applied, but it doesnât stick.
