Need a call to action after adding 2FA on a 2FA-required site
I just signed up on a site that requires 2FA for accounts. Immediately after creating my account I’m forced to this screen:
It’s obvious that I needed to add at least one authenticator to continue, however after adding them the message
You are required to enable two-factor authentication before accessing this site.
does not go away, nor is there a clear next step.
Were I not already familiar I might wonder “Do I need to trigger a save? Where do I go next?”
I suggest:
  • have the error message change to e.g. “You have added at least one authenticator, you may add additional methods or [continue] to the site.” with a green background
  • perhaps add a Continue button at the bottom to give the user a clear CTA
This is good feedback. I’d make sure to highly discourage leaving this screen with a single Security Key as the only option - insist that a second SK or alternate option is enabled.
While observing someone else go through this:
  • they weren’t sure which button to hit to add a U2F Yubikey or a TOTP
  • they weren’t sure what to call the token and why it mattered
  • they weren’t sure what had been registered after registering Windows Hello as a security key
I think normally someone visiting the 2FA page already knows about these terms, whereas someone on a 2FA-required site might not.
I might change the text to include examples:
Time-Based Tokens
example: Google Authenticator
+ Add TOTP Authenticator
Security Keys
example: Windows Hello, Yubikey, U2F Hardware Tokens
+ Add Security Key
or perhaps (given discussion in internal chat on how to make the process easier for the user):
Time-Based Tokens
Portable Security Keys
example: Yubikey, U2F Hardware Tokens
+ Add Security Key
Platform Security Keys
example: Windows Hello, Apple FaceID
+ Add Security Key
