Serve aiuto per personalizzare l'intestazione del titolo
Hello Guys,
I need some help to truncate certain portion of the header as if it was not there. I want to remove the area marked in red in the image. somehow cover the area marked in red, with black color as if it was not there.
Try adding this, pre-adjusted the height and padding.
.d-header {
    padding: 0;
    height: 4.01em;
    background-color: #000;
.d-header .wrap {
    background-color: #fff;
Thanks for the replay. When I added the css, every thing worked fine, except the box shadow. The box shadow went missing. So i made some modification but still the same, no box shadow for header. Need some help over here, @Stranik
see my modified css:
  .d-header {
            padding: 0;
            height: 0.01em;
            box-shadow: 0 2px 4px -1px rgba(0,0,0,0.25);
  .d-header .wrap {
I’m not a designer myself and don’t know css well, but it works for me.
.d-header {
.d-header  .wrap {
    max-width: 1144px;
Thank You so much @Stranik. You solved my problem. See final modification,
.d-header {
    padding: 0;
    height: 0.01em;
    background-color: #323433; //#4e726a;   //Header background Colour
    box-shadow: none;
    width: 100%;
    padding-top: 1px;
    height: 48px;
.d-header  .wrap {
    max-width: 1144px;
Thank You
