Negative SEO because of too much category pages getting indexed
סיכום מבוסס בינה מלאכותית
A discussion about Negative SEO due to excessive category pages being indexed on a Discourse site is underway. veer points out that on meta.discourse.org, 1670 category pages are indexed, but on their own Discourse site with 50 categories, over 23,000 pages are indexed, which is a dangerous signal for SEO due to content duplicacy.
Stranik suggests that possible disallows in the robots.txt file could be the cause. Mittineague questions the assumption that the Google search modifier “site:” behaves in a way that limits results to specific folders.
codinghorror discovers that the issue is caused by weird query strings, such as no_subcategories, slow_platform, and per_page, which result in multiple versions of the same category page being indexed. They propose that a canonical meta-tag should be added to category pages to prevent this issue.
techAPJ reveals that the canonical meta-tag was previously included but was regressed 4 months ago. They fix the issue and add a test case to prevent future regression. The fix is later backported to the beta and stable branches.
If you look for total category pages indexed of meta.discourse.org with following query in google
site:meta.discourse.org/c/
you will find 1670 pages index. Similarly i have a discourse site with 50 categories
while here more than 23 thousand pages are indexed under category. (A very very dangerous signal for seo because of content duplicacy)
It should be fixed otherwise google will penalise a discourse website rankings.
Look at the following screenshot how duplicate pages are created and indexed.
I tried to write about this earlier. This is an example:
https://meta.discourse.org/t/seo-for-discourse-not-working-properly/60709/5?u=stranik
Possible
Disallow: /latest?exclude_*
Disallow: /*?no_subcategories=*
I think it is more correct to look directly into the search index. I don’t know if there is such a mechanism in the Google search engine. In Yandex there is a detailed report: duplicates, poor content, all types of errors, are excluded and the included page, graphics crawls, etc. According to the results, a lot of duplicate pages.
I think you may be expecting the Google search modifier to to behave in a way it doesn’t.
Refine Google searches - Google Search Help
Search for a specific site
Put “site:” in front of a site or domain. For example, site:youtube.com or site:.gov.
Do you have a Google reference that indicates URLs with sub-folders limits results to only those folders?
see snapshot. same cat pages indexed multiple times.
The issue is these weirdo querystrings.. where is this crap coming from?
page I can certainly understand, but…
no_subcategories?
slow_platfom?
per_page?
wtf?
Just combining those three plus page, that’s
16 categories * 4 * 3 * 2 = 384
384 category “pages”
I think I see the problem, and we need to fix it ASAP
https://meta.discourse.org/c/plugin?no_subcategories=false&page=2&slow_platform=20
This page must have a canonical meta-tag like so:
<link rel="canonical" href="https://meta.discourse.org/c/plugin?page=2" />
Can you take this @techapj please? the meta-tag should be served to all clients including Google crawler.
We used to include canonical meta tag on /c/plugin page but (I think) this was regressed 4 months ago when we introduced “Default Topic List” category setting.
This should now be fixed, and a test case is added to prevent future regression.
https://github.com/discourse/discourse/commit/72c92b0f4e2c324a9902613c9464fc45bf7fc09b
Now all the category pages should have canonical meta tag except the Top category page (/c/plugin/l/top).
We should probably backport this fix..
Okay, backported this fix to beta and stable branch.
