Ning import script
Holy moly. Thanks for that “how to find it” link, because. . . WTF?
Well, I’m on 24.0.0.180. I’m going to see if I can figure out how to download that next. I was hoping that I’d figure out this Ning import and add it to my menu of services. I’d thought I might offer to download the data, since it’s, complicated, but if my experience thus far is an indicator, I cannot imagine being willing to do so for under $1000. Maybe downgrading will help.
EDIT: I downgraded to Air 22.0.0.153. I still got the same errors, but the JSON files parse, anyway. Whether 22.0.0.153 was the answer, I do not know, but if you are having trouble getting data from Ning, you might try this. You can download old versions here.
Am I correct in understanding that in order to use the Ning import script, I have to set up a separate development environment using Vagrant, and that this import script can’t be used in a Docker-based Discourse installation? If that’s the case can someone point me to a guide for doing the Vagrant-based installation, please?
Thanks!
That’s how I did it, mostly because I wanted to have two environments. One for testing and one for production. It was cheaper/faster/simpler to use Vagrant for testing, but YMMV.
I used this guide: https://github.com/discourse/discourse/blob/master/docs/VAGRANT.md
Thanks Alex, I’m working through the guide you linked, it’s currently downloading the Vagrant container. I know literally nothing about Ruby so here’s hoping it turns out okay :slight_smile:
