אין מחלקה ספציפית למצב כהה
Continuing the discussion from How to add a specific body class for the dark (or light) mode?:
Is this still the case?
I’d like to add specific CSS for an external widget (a leaflet map) when dealing with a dark theme, is it still not possible to identify using just a CSS selector?
Of course I can just create a Theme Component to apply the changes and assume the admin just adds that to the Dark Scheme, but that won’t switch automatically … (which is the current solution)
Would this accomplish what you need? this would need to be added to color_definitions.scss
@if #{schemeType()} == dark {
    body {
        background: red;
} @else {
     body {
        background: blue;
A class does seem like it would be useful though, we can probably add one.
Thanks for your suggestion.
Yeah, doesn’t need to be a class so long as I can distinguish in CSS.
Dumb question: how can I do that from within a Theme Component or Plugin?
In a remote theme or component you can create a file common/color_definitions.scss — if you’re looking to add CSS via the admin panel there’s a section there:
Screenshot 2023-02-13 at 10.55.17 AM
Thanks @awesomerobot!
