NoMethodError: undefined method `should_secure_uploads? - 최신 업데이트
안녕하세요,
디스코urse와 플러그인을 업데이트한 이후로 이메일을 보내지 못하고 있습니다. Sidekiq에서 다음과 같은 오류가 발생하고 있습니다.
Jobs::HandledExceptionWrapper: Wrapped NoMethodError: undefined method should_secure_uploads?’ for #<Post id: 3568, user_id: -2, topic_id: 3224, post_number: 1, raw: "A new campaign conducted by the T…`
이미지 호스팅을 위해 AWS S3를 사용하고 있습니다.
전체 로그
activemodel-7.0.8.1/lib/active_model/attribute_methods.rb:450:in `method_missing'
/var/www/discourse/lib/pretty_text.rb:656:in `format_for_email'
/var/www/discourse/app/helpers/user_notifications_helper.rb:59:in `email_excerpt'
/var/www/discourse/app/mailers/user_notifications.rb:279:in `block in digest'
/var/www/discourse/app/mailers/user_notifications.rb:278:in `map'
/var/www/discourse/app/mailers/user_notifications.rb:278:in `digest'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:215:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:151:in `process'
actionmailer-7.0.8.1/lib/action_mailer/rescuable.rb:27:in `block in process'
actionmailer-7.0.8.1/lib/action_mailer/rescuable.rb:19:in `handle_exceptions'
actionmailer-7.0.8.1/lib/action_mailer/rescuable.rb:26:in `process'
actionview-7.0.8.1/lib/action_view/rendering.rb:39:in `process'
actionmailer-7.0.8.1/lib/action_mailer/base.rb:646:in `block in process'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.0.8.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `instrument'
actionmailer-7.0.8.1/lib/action_mailer/base.rb:645:in `process'
actionmailer-7.0.8.1/lib/action_mailer/message_delivery.rb:128:in `block in processed_mailer'
<internal:kernel>:90:in `tap'
actionmailer-7.0.8.1/lib/action_mailer/message_delivery.rb:127:in `processed_mailer'
actionmailer-7.0.8.1/lib/action_mailer/message_delivery.rb:30:in `__getobj__'
/usr/local/lib/ruby/3.2.0/delegate.rb:84:in `method_missing'
/var/www/discourse/lib/email/sender.rb:51:in `send'
/var/www/discourse/app/jobs/regular/user_email.rb:79:in `send_user_email'
/var/www/discourse/app/jobs/regular/user_email.rb:39:in `execute'
/var/www/discourse/plugins/chat/lib/chat/user_email_extension.rb:6:in `execute'
/var/www/discourse/app/jobs/base.rb:305:in `block (2 levels) in perform'
rails_multisite-6.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
rails_multisite-6.0.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:292:in `block in perform'
/var/www/discourse/app/jobs/base.rb:288:in `each'
/var/www/discourse/app/jobs/base.rb:288:in `perform'
sidekiq-6.5.12/lib/sidekiq/processor.rb:202:in `execute_job'
sidekiq-6.5.12/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:132:in `call'
sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:182:in `invoke'
sidekiq-6.5.12/lib/sidekiq/processor.rb:169:in `block in process'
sidekiq-6.5.12/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
sidekiq-6.5.12/lib/sidekiq/job_retry.rb:113:in `local'
sidekiq-6.5.12/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
sidekiq-6.5.12/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
sidekiq-6.5.12/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
sidekiq-6.5.12/lib/sidekiq/processor.rb:263:in `stats'
sidekiq-6.5.12/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
sidekiq-6.5.12/lib/sidekiq/job_logger.rb:13:in `call'
sidekiq-6.5.12/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
sidekiq-6.5.12/lib/sidekiq/job_retry.rb:80:in `global'
sidekiq-6.5.12/lib/sidekiq/processor.rb:124:in `block in dispatch'
sidekiq-6.5.12/lib/sidekiq/job_logger.rb:39:in `prepare'
sidekiq-6.5.12/lib/sidekiq/processor.rb:123:in `dispatch'
sidekiq-6.5.12/lib/sidekiq/processor.rb:168:in `process'
sidekiq-6.5.12/lib/sidekiq/processor.rb:78:in `process_one'
sidekiq-6.5.12/lib/sidekiq/processor.rb:68:in `run'
sidekiq-6.5.12/lib/sidekiq/component.rb:8:in `watchdog'
sidekiq-6.5.12/lib/sidekiq/component.rb:17:in `block in safe_thread'
/var/www/discourse/lib/cooked_post_processor.rb:25:in `initialize'
/var/www/discourse/app/jobs/regular/process_post.rb:27:in `new'
/var/www/discourse/app/jobs/regular/process_post.rb:27:in `block in execute'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/app/jobs/regular/process_post.rb:8:in `execute'
여기서 해당 메서드가 최근에 이름이 변경된 것을 확인했습니다: DEV: Rename with_secure_uploads? to should_secure_uploads? on Post - Pull Request #26549 - discourse/discourse - GitHub.
관리자 패널에서 업그레이드를 수행하셨나요?
이 분야 전문가가 아닙니다. 모든 것이 올바르게 로드되도록 Discourse를 명령줄에서 다시 빌드해야 하는지 궁금합니다. :thinking:
관리자 UI에서 그렇게 했습니다. 보통은 문제가 없어요. 방금 드롭레트를 재시작했는데도 여전히 남아 있어서, 이제 리빌드를 시도해 보겠습니다.
그렇게 고치니까 해결됐네요. 잘 찾아주셨어요! 정말 감사합니다.
