Vecchia immagine Docker
I finally upgraded our discourse server (including OS & Docker).
I had to destroy and bootstrap again because of problems. It’s running v1.6.0.beta1 +178 now but I still see only this image:
root@disc:~# docker images
REPOSITORY             TAG                 IMAGE ID            CREATED             SIZE
local_discourse/app    latest              370fea60556d        36 minutes ago      1.635 GB
samsaffron/discourse   1.0.8               76762729d2a1        13 months ago       1.143 GB
Is this correct?
Try running
./launcher cleanup
bootstrap, etc. all worked but this fails with:
root@disc:/var/discourse# ./launcher cleanup
The following command will
- Delete all docker images for old containers
- Delete all stopped and orphan containers
Are you sure (Y/n):
Starting Cleanup
awk: line 2: function strftime never defined
awk: line 2: function systime never defined
write /dev/stdout: broken pipe
8078820
8078816
awk: line 1: syntax error at or near *
awk: line 1: extra ')'
awk: line 1: syntax error at or near {
./launcher cleanup cleared up 4 of disk space.
Btw, samsaffron/discourse 1.0.8 is the only image on the system. Should bootstrap have downloaded a newer one? It updated everything else.
try…
cd /var/discourse
git pull
./launcher rebuild app
Also be sure to type the word “cd” in blue, that part is very important. If you use a regular non-blue cd command, it won’t work.
Can’t rebuild at the moment but I’ll try as soon as the colors align!
It worked, thanks!
Not sure how I can say that so I meet the 20 character minimum. Maybe “Dude, it pulled, it rebuilt and then it fukcing launched. Totally discourse!”
Suggestion, just select my answer as an “accepted answer” even less work than typing 20 chars :slight_smile:
9 Mi Piace
