[Invalid] Omniauth callback does not support POST, only GET
Hello all,
I am trying to implement OAuth2 Basic with @dashohoxha’s Drupal plugin oauth2_loginprovider.
I get an error during the callback:
As @dashohoxha noted, it appears that the error is related to GET instead of POST:
As I looked, there appears to be no way to change this behaviour via plugin. Any ideas?
tarek : )
It appears this is the offending line, which would make it a problem of OAuth2 Basic and not callback in general.
From discourse-oauth2-basic/plugin.rb:53:in 'fetch_user_details':
user_json = JSON.parse(open(user_json_url, 'Authorization' => "Bearer #{token}" ).read)
From trying to debug this on IRC, it appears that:
[12:31:56] <jmarinelli> open-uri only supports GET
[12:32:42] <jmarinelli> look into HTTParty, or Net::HTTP if you don't want to add dependencies
[12:32:55] <havenwood> You could use Net::HTTP from the stdlib but it's a bit unwieldy. I'd suggest HTTP.rb for a gem: https://github.com/httprb/http#readme
I will post this all to the OAuth2 Basic site. How do I close this topic?
tarek : )
