Uno de los spec de TopicEmbed.import falla con Ruby 3
Me gustaría obtener ayuda con el fallo en la especificación TopicEmbed.import con Ruby 3.
Pasos para reproducir
cd discourse
bundle exec rspec ./spec/models/topic_embed_spec.rb:154
Comportamiento esperado
Debería finalizar con éxito.
Comportamiento real con Ruby 3.0.2
$ bundle exec rspec ./spec/models/topic_embed_spec.rb:154
Run options: include {:locations=>{"./spec/models/topic_embed_spec.rb"=>[154]}}
Randomized with seed 41701
F
Failures:
  1) TopicEmbed.import embedded content truncation keeps everything in the imported post when truncation is disabled
     Failure/Error: expect(post.raw).to include(long_content)
       expected "<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa...for the original entry at <a href=\"http://eviltrout.com/123\">http://eviltrout.com/123</a></small>" to include "<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa...for the original entry at <a href='http://eviltrout.com/123'>http://eviltrout.com/123</a></small>\n"
       Diff:
       @@ -1,4 +1,7 @@
       -<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa</p>\n<p>more</p>\n<hr>\n<small>This is a companion discussion topic for the original entry at <a href='http://eviltrout.com/123'>http://eviltrout.com/123</a></small>\n
       +<p>aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa</p>
       +<p>more</p>
       +<hr>
       +<small>This is a companion discussion topic for the original entry at <a href="http://eviltrout.com/123">http://eviltrout.com/123</a></small>
     # ./spec/models/topic_embed_spec.rb:158:in `block (4 levels) in <top (required)>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
Finished in 2.48 seconds (files took 2.73 seconds to load)
1 example, 1 failure
Failed examples:
rspec ./spec/models/topic_embed_spec.rb:154 # TopicEmbed.import embedded content truncation keeps everything in the imported post when truncation is disabled
Comportamiento real con Ruby 2.7.4
$ ruby -v
ruby 2.7.4p191 (2021-07-07 revision a21a3b7d23) [x86_64-linux]
Randomized with seed 4126
Finished in 2.51 seconds (files took 2.31 seconds to load)
1 example, 0 failures
Lo que he encontrado hasta ahora
Agregué algo de código de depuración con print y descubrí que long_content dentro de topic_embed_spec.rb estaba siendo sobrescrito por contents de app/models/topic_embed.rb.
Código de depuración con impresión
$ git diff
diff --git a/app/models/topic_embed.rb b/app/models/topic_embed.rb
index 1e9f06a322..ab407d8005 100644
--- a/app/models/topic_embed.rb
+++ b/app/models/topic_embed.rb
@@ -28,6 +28,7 @@ class TopicEmbed < ActiveRecord::Base
   # Import an article from a source (RSS/Atom/Other)
   def self.import(user, url, title, contents, category_id: nil, cook_method: nil, tags: nil)
+    p "contents.length at the begining of self.import: #{contents.length}"
     return unless url =~ /^https?\:\//
     if SiteSetting.embed_truncate && cook_method.nil?
@@ -102,6 +103,7 @@ class TopicEmbed < ActiveRecord::Base
+    p "contents.length at the end of self.import: #{contents.length}"
     post
diff --git a/spec/models/topic_embed_spec.rb b/spec/models/topic_embed_spec.rb
index 8659eb7d56..1266441da7 100644
--- a/spec/models/topic_embed_spec.rb
+++ b/spec/models/topic_embed_spec.rb
@@ -153,7 +153,9 @@ describe TopicEmbed do
       it 'keeps everything in the imported post when truncation is disabled' do
         SiteSetting.embed_truncate = false
+        p "long_content.length before calling TopicEmbed.import: #{long_content.length}"
         post = TopicEmbed.import(user, url, title, long_content)
+        p "long_content.length after calling TopicEmbed.import: #{long_content.length}"
Resultado con Ruby 3.0.2
Randomized with seed 24988
"long_content.length before calling TopicEmbed.import: 119"
"contents.length at the begining of self.import: 119"
"contents.length at the end of self.import: 267"
"long_content.length after calling TopicEmbed.import: 267"
F
Failures:
       Diff:
       @@ -1,4 +1,7 @@
       +<p>more</p>
       +<hr>
     # ./spec/models/topic_embed_spec.rb:160:in `block (4 levels) in <top (required)>'
Finished in 2.55 seconds (files took 3.4 seconds to load)
Failed examples:
Resultado con Ruby 2.7.4
Randomized with seed 1802
"long_content.length after calling TopicEmbed.import: 119"
Finished in 2.56 seconds (files took 3.06 seconds to load)
3 Me gusta
He descubierto por qué esta especificación falla solo con Ruby 3.0.2.
Desde Ruby 3, las cadenas interpoladas no están congeladas, incluso si está habilitado el comentario mágico frozen-string-literal.
Por lo tanto, aquí hay posibles formas de solucionarlo.
  1. Usar contents.dup en lugar de +contents
$ git diff
index 1e9f06a322..502409d3c1 100644
@@ -34,7 +34,7 @@ class TopicEmbed < ActiveRecord::Base
       contents = first_paragraph_from(contents)
     contents ||= ''
-    contents = +contents << imported_from_html(url)
+    contents = contents.dup << imported_from_html(url)
     url = normalize_url(url)
  1. Congelar long_content interpolado
index 8659eb7d56..a25351a586 100644
@@ -142,7 +142,7 @@ describe TopicEmbed do
     describe 'embedded content truncation' do
       MAX_LENGTH_BEFORE_TRUNCATION = 100
-      let(:long_content) { "<p>#{'a' * MAX_LENGTH_BEFORE_TRUNCATION}</p>\n<p>more</p>" }
+      let(:long_content) { "<p>#{'a' * MAX_LENGTH_BEFORE_TRUNCATION}</p>\n<p>more</p>".freeze }
       it 'truncates the imported post when truncation is enabled' do
         SiteSetting.embed_truncate = true
Tengo la inclinación de abrir una solicitud de extracción (pull request) para usar contents.dup y descubrí que la idea fue implementada pero revertida en Revert "FIX: Use #dup instead of #+@ since content could be an instan… · discourse/discourse@d01c938 · GitHub
No encontré otros antecedentes para la reversión; me gustaría escuchar a los colaboradores/mantenedores.
2 Me gusta
Se abrió FIX: Ruby 3 does not freeze interpolated string by yahonda · Pull Request #14567 · discourse/discourse · GitHub
2 Me gusta
