Onebox non visualizza - iFramely passa
I have noticed very few sites I attempt to use a Onebox for are not working. I checked
against iframely.com and it displays as expected. Iframely URL Debugger - Open Graph, Twitter Cards, oEmbed does not indicate any errors.
Is there something else I can check?
My guess is you are having your crawl rejected (and this is happening here on meta too).
But I have a solution, but it’s not 100% free:
I just tested this on two of my sites, one equipped with the plugin, and one without, and it works on the one equipped.
My pleasure! :wink:
One of the issues here is that Discourse/Onebox could be a heck of a lot more transparent about the way it handles a failure. I guess that’s a stretch feature, but it would be nice if there was more feedback to the user pasting the link (or even just the admins).
I checked my /logs on the site which failed and do not see any extra information wrt to the failed preview …
This is funny, that site blocks “forum” in the User Agent:
Works:
  • Discourse
  • Discourse Onebox
  • Discourse Onebox v1.8.0.beta13
Don’t Work:
  • Discourse Forum Onebox v1.8.0.beta13
  • Discourse Forum
  • Forum
Yes, I can reproduce that from a VPS using curl -A "-string-"! Can we have a setting to change the user agent? :wink:
In this case that would be a lot less hassle :slight_smile:
Oh wait, I see a file:
discourse/config/initializers/100-onebox_options.rb
require_dependency 'twitter_api'
Onebox.options = {
  twitter_client: TwitterApi,
  redirect_limit: 3,
  user_agent: "Discourse Forum Onebox v#{Discourse::VERSION::STRING}"
Take the word forum out?
I could easily add this to my plugin of course …
